Wanted to have a list of breakdowns/issues and the needed repair that users have had with the Ioniq EV. Please include year and trim of vehicle. My goal will be to create a spreadsheet with types of real world issues and repairs.
No detaisl other than it was replaced on Hyundai's recommendation. The EPB failure warning has not appeared since.Woah, imagine getting that after the warranty expired! If keeping the car until it reaches the end of its useful life, an extended warranty isn't a bad idea. Did Hyundai go into detail about what was wrong with the drive unit?
Update2020 premium SE.
1) Intermittent creaking from rear when going over bumps, initially I thought this was a loose rear seat U fixing, but now I am fairly sure it's coming from the hatchback itself. Have seen other people had similar issues, will let dealer know at first service in Feb.
2) Flat 12 volt, 5 times, 4 trips to dealer. First 3 times no apparent cause, battery changed at second time. At the last occurrence an error code pointed them to the passenger side door locks which had no/faulty water proofing on the electrical contacts shorting them out and keeping the car awake. Several of these happened after rain or washing the car.
3) Loose hinge on offside passenger side rear seat with plastic cone bush found loose in the hinge, sorted on one of the many trips to sort out the 12volt.
I couldn't find anywhere actual photos of the cells on google, and I really searched a lot before posting to this thread.Google Images? Here's one for example:
2019 HYUNDAI IONIQ HYBRID 37501-G2100 High Voltage Battery 065 | eBay
I also had this a while back, but then again I’m sure it was caused by the weather conditions (it was raining cats and dogs).Had an issue with the Smart Cruise Control today. A red triangle with an exclamation mark appeared on the dash and the display said the conditions for smart control could not be met. Thirty seconds later the triangle disappeared and everything went back to normal.
Wanted to reply to my own post as an update I've gotten my IBAU replaced which resolved the annoying clicking noise and excessive hissing noise while using the brake pedal and it's also not as spongy as before. One of the stickers on the unit says Ver. 6.7 though I didn't remember to see what the old one from the factory was. Doh.2018 EV and here's my list so far at 31,000 KM. Beginning not to like the outlook for long term reliability with my Ioniq EV if things keep mounting.
1. Driver's side door handle keyless entry button went dead. Replaced.
2. Charge Actuator went bad. Replaced.
3. Brake problem. IBAU going bad, going to get replaced soon.
I have a few other intermittent annoying problems which I left out too.
I'd consider the first minor and the other two major deals. Imagine these go bad out of warranty, it'll cost more than $3500 out of pocket. And factor in having to deal with bad dealers who don't want to do work and going to the next place, and going back and forth is a hassle and having to take days off work.
If things keep mounting up and if these problems come back and need early replacement again, I might look to sell the car and possibly not continue with Hyundai for another decade or two once they improve their long term reliability.
I think I'm eventually going to have to go in regarding the air conditioner, which I read is another thing other Ioniq owners have had to deal with. Seems this part fails too prematurely.
Crap man, you're having terrible luck with your IONIQ. Certainly not what most IONIQ owners are experiencing.Edit Sep 21: Oh my goodness I spoke too soon. The brake noise with the pedal has returned and gotten worse than before. Can't believe this.
It's so strange. The noise came back 7 days later with new IBAU but now a metal sounding screeching noise.Crap man, you're having terrible luck with your IONIQ. Certainly not what most IONIQ owners are experiencing.
Keep us posted. I'm interested to hear how this turns out. My IONIQ has over 120k km on it and so except for the battery and power train, is now out of warrantee.It's so strange. The noise came back 7 days later with new IBAU but now a metal sounding screeching noise.
Forward to the next morning, it appears to have lessened substantially, almost back to nothing.
So it appears to be intermittent now. I think it seems to happen when the car is sitting in the heat. Come morning time it's cold and doesn't seem to happen is what I think is happening.
Maybe system needs to be flushed multiple times.
Dealer visit #3 coming up...
it's the gasket : after cleaning, it disappears (ioniq4 06/2020)Right front door makes a screeching noise when opened or closed. Sometimes it disappears...and comes back later. It does not come from gasket, and the hinges have been oiled and greased in Hyundai service. No big deal but lowers the feeling of quality quite a lot.
Have any photo of which gasket you are talking about?it's the gasket : after cleaning, it disappears (ioniq4 06/2020)
