Wanted to have a list of breakdowns/issues and the needed repair that users have had with the Ioniq EV. Please include year and trim of vehicle. My goal will be to create a spreadsheet with types of real world issues and repairs.
It may well be the gasket, actually. Door gasket/main seal. Put silicon based something near mirror where the gasket meets frame when closing.Have any photo of which gasket you are talking about?
I know this is an old thread, but did you ever get to the bottom of this? I have a new 2021 model which is doing the same.1. Charging at only 5kwh using level 2 (should be 7.2kwh)
Come to think of it I took a photo of the error message: Check electric vehicle systemJust wanted to add to this thread that my 28kwh 2017 Ioniq Electric with about 80k km on odometer fully broke down on the road while driving in May
I was driving on a smaller road and was about to overtake a slower driver when abruptly all my torque was cut off
In fact it was so abruptly that it felt like a shaft had broken straight off
However what really happen was that car was put in neutral and from this point on I was coasting along only by the inertia of the car
Luckily there was a bus-stop coming up where I managed to park (no regen only physical breaks)
Tried to put car back in drive, but it wouldn't allow me
Had previously red about problems with 12V battery without having problems myself but tried disconnecting 12V battery for 5 minutes but nothing did the trick
This was about 12 in the night and I had to stop a random car to call a family member because my phone ran out of juice
When family member arrived we tried using jumper-cables but car was still stuck in neutral
In the end car was towed back home to family member, and I left 12V battery to charge overnight still thinking this was the problem
When this did not work, I had to leave the car where it was to leave for work the next day on a 2-hour train ride
Same day I got road-assist to tow car to the closest Hyundai-dealer that I had talked to prior to the tow
After a week they told me they had to transfer the car to a different dealer because they lacked high voltage certification
Even thought car was still under warranty I was told not to be given a courtesy car
Reason given was that car was originally sold in Sweden and was later registered in Norway (car was bought second-hand by me in Norway, so this was new information)
6 week after car was towed to dealership and after many phone calls I got to pick it up again after another 2 hour train ride back to dealership
Turned out the problem was faulty power relay assembly which they replaced under warranty (although they where very hesitant to document the fact)
I know this power relay assembly is subjected to a recall on the Ioniq Hybrid but my car is the fully electric variant
Cant find any other reports of any power relay assemblies breaking down in this thread nor any other place online
Good thing this did not happen on my 3000km road trip last summer![]()
2020 38 KW battery pack. 12volt battery died because it was manufactured in 2019 and sat in the car in a cold environment before I got it. Charge port lock pin, AC would charge fine, DC charger require the charging lead to be locked in so car would not charge on DC.Wanted to have a list of breakdowns/issues and the needed repair that users have had with the Ioniq EV. Please include year and trim of vehicle. My goal will be to create a spreadsheet with types of real world issues and repairs.
Apparently posting in old threads is not desirable, so I made a new threadThis is an older thread, you may not receive a response, and could be reviving an old thread. Please consider creating a new thread.
This message is awaiting moderator approval, and is invisible to normal visitors.
Hi, tegnap megkaptam a 2018-as Ioniq akkumulátort, és már elkezdtem szétszedni, felteszek néhány fotót alább, és ahogy haladok előre, további képeket is teszek közzé
A teljes akkumulátor teteje
3 nagy csatlakozó található, egy felül, a hátoldalon és egy az elülső oldalon
CMU (cellafigyelő egység)
View attachment 33671 View attachment 33672
A felsĹ‘ burkolat eltávolĂtva
View attachment 33673 View attachment 33674
Nagyon tetszik a lĂ©gáramlási rĂ©sz kialakĂtása, a fĹ‘ akkumulátorban összesen 192 tasakos cella van, 2 párhuzamosan vezetĂ©kezett tasakos cella van, mindkettĹ‘ alumĂnium tokban, ezek a tokok egymásra vannak rakva, Ă©s van egy 4 mm-es rĂ©s az alumĂnium tokok között, a lĂ©gáramlás az összes alumĂnium tok között megy, Ăgy minden tasakcellát a felette vagy alatta áthaladĂł levegĹ‘ hűt. Az alábbiakban egy 20 tasak cellás csomag egy rĂ©sze láthatĂł, 2p10s-ben konfigurálva. Az ioniq 6 nagy 2p10-es Ă©s további 6 kisebb csomaggal rendelkezik 2p6s konfiguráciĂłban.
Mindegyik csomag egyik oldalán fűtĹ‘fĂłlia van, ezt valĂłszĂnűleg tĂ©len használják, biztos vagyok benne, hogy ez sikerĂĽlni fog; ne kezdje el tölteni a csomagokat, mielĹ‘tt a cellák elĂ©rik a normál töltĂ©si hĹ‘mĂ©rsĂ©kletet (tudd meg, hogy a drĂłnjaim nem indulnak el ha a cellák hĹ‘mĂ©rsĂ©klete 5°C alatt van)
További képeket teszek fel, ha valakit még érdekel, kérdezzen
[/IDÉZET]
SegĂtsĂ©get szeretnĂ©k kĂ©rni, hátha tudtok segĂteni...
