41 - 60 of 178 Posts
Every ioniq brand and model.
Thanks, just updated! Is there a method to fix the speed limits being one out, or is it just a case of waiting for a new update? :)
Also if my local dealers goes to update my software in the future and sees references to the RUS files (like the Solaris_SD_Card_RUS.ver) file, would that void my warranty? Sorry for all the questions, I just got my car (unfortunately still with 2017 software) and I don't wanna break anything this early :D
Discussion starter · #42 ·
Hey mate, seems this speed limit issue is related to UK only. A euro week be out on few weeks.
Your dealer won't see any reference to RUS, don't worry. Your sd card will be overwritten when he updates it.
6. open the full engineering menu, a choose ADP opton and enable ETHERNET
Hello SonicSpinner,
a friend of mine asked me to update their Ioniq, which has fw version 200731.
At the moment it's un-touched, but we want to install AppManager (before the upate) and IoniqInfo (after the update).
I was able to get in Engineering Mode, using the "virtual num-pad" method (just similarly to your video about fw 191209)
But there is no "ADB option" in this Engineering Mode.
(And there is no "Prepare Auto Test" under the Tuning item)
Do you know, how can I enable this option with fw version 200731?
Hello SonicSpinner,
Try the "Easy Fire Tools" method and setup your phone as hotspot.
Discussion starter · #45 ·
Hello SonicSpinner,
If he has the 200731 fw and no appmanager installed, then it's too late.
You can rollback to 2018 fw with a special fw we have. Then from there you can use the good old screen saver trick to get into engineering mode and install appmanager.
Then update to this latest version
Discussion starter · #51 ·
Thank you.
Should I use a new/empty SD card, or the one in the car?
you can use the same, format is and copy over.
when done, format it again and prepare the new update. but install appmanager first.
2018 version app installaation is through screen saver trick, youtube; Hacked hyundai headunit, from kompkiller
Hi SonicSpinner
I use for my Hyundai Ioniq the updates you have in your repository with the name "Hyundai_LGE_2020_2", I appreciate it very much.
I am trying to update the "Hyundai_LGE_2021_1" but I don't know what to do with the SOP file "upgrade.lgk".
I put it in the SD and it does not recognize it as an update.
Please could you help me?
Thank you very much and best regards.
Discussion starter · #58 ·
Hi SonicSpinner
Hey buddy
Make sure your sd card look like this
33994
The Caveneu_h folder is here
The rest of files (maps) are here
@SonicSpinner Thanks for the files!
I updated today as my workshop missed it at service last week and I was still on the 19 update. Ioniqinfo got reset but works out of the box. Appmanager and the associated shortcut to eng-mode app works too, seems a littlr buggy to get into appmanager, it sometimes goes to the versions screen. ABRPtransmitter however seems to shutdown on starting, not got it working yet. Gonna see if leaving it alone overnight after clearing data/cache will rectify otherwise ill reinstall it tomorrow, I had the latest no-map verson installed.
I could not find anything new in the update, hopefully the music shuffler algorithm has been improved, but I guess updated maps are nice too...
