61 - 80 of 178 Posts
Discussion starter · #61 ·
@SonicSpinner Thanks for the files!
I updated today as my workshop missed it at service last week and I was still on the 19 update. Ioniqinfo got reset but works out of the box. Appmanager and the associated shortcut to eng-mode app works too, seems a littlr buggy to get into appmanager, it sometimes goes to the versions screen. ABRPtransmitter however seems to shutdown on starting, not got it working yet. Gonna see if leaving it alone overnight after clearing data/cache will rectify otherwise ill reinstall it tomorrow, I had the latest no-map verson installed.
I could not find anything new in the update, hopefully the music shuffler algorithm has been improved, but I guess updated maps are nice too...
Reinstall it, it's best. Also note that keyboard on 3td party apps are bugged now. You can't see what you are typing, but it's typing. So when you have to enter your abrp token to login first time, pray that you write it the first time hahs
Discussion starter · #62 ·
Updated well but after opening the app manager I got the stock android UI buttons going. If not remembering wrong this happend before and we knew a fix?!
Not sure what you mean. Is that the CTS menu you are talking about? If yes you should be able to disable it on the engineering menu full, under adb and CTS menu
Got a normal android tablet look to the unit but it went away after the car was off for 10min and the unit rebooting.
Wondering if the .wav can be changed. Topgun quotes would be fun for the speed camera warnings.... will explore this when I have time, the files are there atleast
Discussion starter · #65 ·
Aah yes. It's the CTS menu. You can enable that in the engineering menu too. The real android backend will show. Can be handy and customizable
A quick update if anyone else had trouble with abrptransmitter. Reinstalling via firetools got it working properly again.
While installing some apps I got the android volyme muted. some chimes and navigation + radio worked but not nature sounds, bluetooth etc. factory reset did not help. I searched google and found an apk compatible with the old headunit so I could open that and manually get the volyme slider all the way up.
non of the usual apps such as sorrento audio could do it. Just a little pro tip :)
Could you please tell me which files I have to download to update software and maps for my KIA Carens IV (Switzerland)? I'm interested in EUR version. By the way - is the official EUR software and maps already available?
Hyundai Ioniq 2017 - Romania, no problems with speed warnings, they're shown properly.
Update took around 10 minutes from start to finish.
One thing I noticed, is that all radio stations now have names, I seem to remember that it was a pain to search for the right station before, even from favourites.
Colours are not as lively on map, but I like it, it seems to not be as distracting, also I like the new way of rotating through turns when following a route (It seems smoother).
Discussion starter · #79 ·
Cool. Now you can update again to a newer map :D
New thread is created
I'll give this a try, but I have a feeling it's not going to fix classic UK Ioniq nav speed limit signs as the software is probably what's bugged, not the maps.
