Has anyone successfully managed to enter engineering mode on the Ioniq 5? The usual tricks to enter it don't appear to work on this model.
Let us know if there is anything useful in eng mode.I finally able to get the code for 2023 Indonesian version. RHD and RWD non bluelink.
Follow these steps:
What I don't know is the use of those functions. I'll share a clip later on about the listed menus.
- Change media to FM Radio
- Set volume to 2
- Go to Setup -> General
- Tap 7 times on the left side of Update button
- Tap 1 time on the right side of Update button
- Input 2504 as password
cc @anthoj
IMHO you need a 0 in front.. Mine works like this 0 then 7 (right button) etc.Go into settings to the screen that shows system info and the update button on the bottom then turn volume to 7 press on the screen in the position indicated below. Then turn volume to 3, press again then turn volume to 1 and press again. Should bring up a screen asking for a code.
Very interesting. What do you all think is the difference between the Telematics and the Modem toggles shown here in the Variant Coding menu?
There is no post number 108. It skips from 107 to 109.It does, Ioniq 5 engineering mode post#108, and I posted how to enable it here: Ioniq 5 route planner update?
Hi, you mentioned the code and specific process showed by "The Ioniq Guy" but there is no "Ioniq Guy" in the post to which you replied. What specific post and/or video are you referring to? *EDIT: I see it now in a post lower down on the screen.I can confirm that the code and specific process showed by The Ioniq Guy works on my ‘23 i5 Limited with the latest updates.
Excellent! Could I trouble you to let me know whether tapping the Bluetooth tab in the Module Info section of the Engineering Mode gives you any option to turn off the car's Bluetooth? And, if so, does Bluetooth turn back on by itself after the car is turned on again?And I can confirm error between keyboard and brain -- I was using the correct passwords, but not the correct protocol to enter engineering mode. So either I was trying to enter the password for something else, or I hit a dummy password prompt thrown up by Hyundai.
Following the directions in that video correcly, and not mixing in anything in from Europe or etc. has indeed allowed me access to engineering mode on the latest (230203) head unit software. Thanks for the help, as I likely wouldn't have reviewed that otherwise.
Thank you. Just to confirm, this is for the U.S. version of the Ioniq 5, right? Also, could you check for me, either in the "Connected Car Service" or "Variant" tabs in the Dealer Mode, or in the "Module Info" or "System" tabs in the Engineering Mode, is there any option to turn off the car's Telematics, Modem, or Bluetooth? Thanks!Dealer and Engineering Mode por US version IONIQ 5
Is your car a 2022 or 2023 Ioniq 5?And I can confirm error between keyboard and brain -- I was using the correct passwords, but not the correct protocol to enter engineering mode. So either I was trying to enter the password for something else, or I hit a dummy password prompt thrown up by Hyundai.
This forum noob has no idea what that means, but hey it's all cool -- I see all the info now. By the way, is your car a 2022 or 2023 model year?Put the view in original (flat) mode and you’ll see all the replies.
Put the view in original (flat) mode and you’ll see all the replies.There is no post number 108. It skips from 107 to 109.It does, Ioniq 5 engineering mode post#108, and I posted how to enable it here: Ioniq 5 route planner update?
LOL the forum noob??? You mean one of the site administrators?? Hahahaha go for a walk bud, watch out for Bluetooth wavesThis forum noob has no idea what that means, but hey it's all cool -- I see all the info now. By the way, is your car a 2022 or 2023 model year?
You misunderstood. I was referring to myself as "this forum noob".LOL the forum noob??? You mean one of the site administrators?? Hahahaha go for a walk bud, watch out for Bluetooth waves
Is your car -- the one for which the code and process in the video works to access Engineering Mode -- a 2022 or a 2023?You misunderstood. I was referring to myself as "this forum noob".
I think you misunderstood. I was referring to myself as a "forum noob" and not to you or anyone else. And there are no exterior Bluetooth waves to be concerned about outdoors (the Bluetooth energy levels inside the cabin of a car are much higher and amplified by the metal structure of the car).LOL the forum noob??? You mean one of the site administrators?? Hahahaha go for a walk bud, watch out for Bluetooth waves
Dude, my sincerest apologies for the misunderstanding!You misunderstood. I was referring to myself
No worries Alex. And there are no exterior Bluetooth waves to be concerned about outdoors (the Bluetooth energy levels inside the cabin of a car are much higher and amplified by the metal structure of the car).Dude, my sincerest apologies for the misunderstanding!
