This is the palaver you need to do on a Land Rover Discovery when the electronic hand brake needs work, I will happily stick with my mechanical foot parking brake
How to adjust the parking brake shoes
• Raise and support the vehicle.
• Remove the wheels and tires.
• Using a suitable diagnostic tool, drive the parking brake to the mounting position.
• Align the access hole with the indicators located on the back plate
• Locate the parking brake shoe adjuster.
• Remove the access plug.
• Use a flat blade screwdriver as a lever to displace the parking brake shoes.
NOTE: The movement of the parking brake shoe will be small and may not be felt when levering.
• Failure to displace the parking brake shoes, will result in incorrect clearance when carrying out the
adjustment step.
• Now, using the screwdriver rotate the brake shoe adjuster to extend it until the brake disc is locked
hand tight. However, do not apply excessive force on the brake shoe adjuster. Failure to follow this
instruction may result in damage to the parking brake system.
• The following steps sets the running clearance for the parking brake shoes.
• Using a suitable marker, mark the position of the brake shoe adjuster.
• The parking brake adjuster must then be rotated back EXACTLY one full revolution (10 clicks), until
the mark is again visible.
• The wedge adjuster must be correctly seated to make sure the parking brake cable is correctly
adjusted.
• Loosen the wedge adjuster Allen screw half a turn.
• Tap the brake disc lightly with a soft faced mallet, around the parking brake shoe location within the
brake disc.
• Tighten the wedge adjuster Allen screw to 6 Nm (5 lb.ft).
• Install the access plug.
• Repeat the above procedures for the other side.
• Take the vehicle out of the mounting position by operating the parking brake twice or via the
diagnostic tool.
• It is now vital to carry out the parking brake shoe bedding-in procedure.
The Bedding in procedure
• You need to bed in the EPB shoes either when you have changed the EPB, shoes or you have changed the rear discs.
• With the Engine running, press the brake pedal fully on and off 3 times. On the third press, hold the brake pedal down.
• With the brake pedal still in the down position, pull the EPB switch upwards 4 times and then downwards 3 times. This must be completed within 10 seconds.
• Your dash display will then show ‘Park Brake Bedding Cycle Active’ or something similar. If it hasn’t, then release the brake pedal and try again.
• You need to ensure that you are on a clear piece of road or land as this procedure needs to be completed 10 times.
• Drive at least 19mph and maximum of 29mph and then apply the EPB switch until you stop. You then need to wait for 60 seconds or drive for 1 mile (to allow the brakes to cool down before repeating the process. If you stop the engine or you drive over 30 MPH, the bedding in process will be cancelled. At the end of the 10th time, the bedding in mode will automatically finish.
