21 - 40 of 64 Posts
Others, which I do not understand, pay to hit a little white ball around a hundred acres…
Nor have I understood that game though rarely has anyone mistakenly called me an outdoor person. When I was much younger I did want to play golf, but could never get past the windmill. Thus ended my golfing career, and interest.
If I never see another ant hill, it will be too soon...
i find it difficult to drive conservatively with 446 lb/ft torque. a couple of days ago, there i am, first at the lite, and alongside is a dodge challenger, loud exhaust. he wanted to get in front, and cut into the lane i was in. so, for about 4 or 5 seconds, i was 16 again. yup. worth every penny.
That scenario is cutting into my efficiency too! Probably at least once a week.
Discussion starter · #24 ·
OP here. Following a test drive ironically I am also drawn to the AWD for that reason. My plan would be to swap out the 20" for 18" for better range and tire replacement price and I would drive in eco 99% of the time, but it would be fun to play that other game too, 1% of the time.
Yep, I’m in ECO mode almost all the time because it has the easiest time with getting smooth acceleration from a stop. Even in ECO mode it will at least keep up with casual stoplight pulls and ahead of most coal-roller’s splash zones.
Our I5 is at about 4.3 miles/kwh after 65k miles of driving. A friend with an Ioniq 6 is more efficient. If you are good with a 4 door sedan and want the best efficiency then look at the I6.
in general I see:
Highway speeds 3-3.5
Local roads 4-5
city is up to 6 miles/kwh
You would expect the Ioniq 6 to be more efficient, and all things being equal it probably is.
However, as I have posted before, our 2023 Ioniq 5 SEL AWD is actually more efficient than our lighter, more aerodynamic 2025 Ioniq 6 SEL RWD for our typical driving (most trips are 1700ft down or up with about 50% curving, steep freeway and the rest country roads or town driving).
Over the last few months (both cars driven similar distance, on similar routes, in normal mode, by the same drivers and in the same climate)
  • 2023 Ioniq 5 SEL AWD averages 4.1 miles / kWh
  • 2026 Ioniq 6 SEL RWD averages 3.8 miles / kWh
The only logical explanation is the 2023 Ioniq 5 SEL AWD has 19" wheels and 2025 Ioniq 6 SEL RWD has 20"wheels. So it seems the slightly smaller wheels overcomes the better aerodynamics of the body and lower weight (one less motor) of the Ioniq 6.
So for someone interested in best efficiency make sure you get small wheels (the EPA estimated range for the Ioniq 6 SE RWD with 18" wheels is 342 miles vs 291 miles for the Ioniq 6 SEL/Ltd RWD with 20" wheels)
I wonder how much real world difference using ECO mode makes driving efficiency? Anyone have some real-world comparative data?
That said we basically stay in Normal Mode apart from occasional use of Sports Mode (in similar situations to the ones @hochiinn describes or short freeway entry ramps etc) and very occasional use of Snow Mode.
Our AWD Drive Ioniq 5 in Sports Mode certainly brings out the grins! I was also pleasantly surprised our Ioniq 6 RWD (in Sports or Normal) is plenty quick enough in most situations. It feels quicker than the quoted acceleration times (probably because of the instantaneous torque typical of all EVs)
For day to day driving and with 3 regular drivers of both cars it is just easier to leave them in Normal Mode and Level 3 regen most of the time (and then no-one get surprised when they get in the car.....)
Makes sense to me, and we do the same for the same reason but with only two drivers.
As others have noted, our Ioniq5 yields better “mileage” than our Ioniq6, both 2025s, both RWD. Don’t get it.
Our 2022 Ioniq 5 (AWD SE) has averaged 4.0-4.1 miles per kWh over the the past three and a half years and 38,000 miles. That involved a mix of town and highway driving but relatively little at Interstate speeds. Most of our highway miles are on mountain roads with speed limits less than 65 mph. The majority of the time it has been in Eco mode and Level 1 regen, although I sometimes use Normal mode, higher regen levels or Auto mode in the mountains.
We are considering trading up to an Ioniq 5 from our Bolt, but are leery of decrease in efficiency compared to our Bolt, currently at 5.2 miles/kWh since resetting the trip odometer over 3000 miles ago. This is a mostly rural driving at 45 mph. A few 2-300 mile trips which included highway driving. Some, but mostly no AC. Driving the speed limit on all roads. Tires at 4 psi over recommended. I would like to know what other similarly conservative drivers are getting with their Ioniq 5s. If you have a number to offer, please include whether R or AWD and wheel size. I do realize this is a trade up in size, power and convenience and that should be worth something, but still not quite ready to make the jump.
I have a 2025 RWD Ioniq 5 Limited. Given the type of driving you do, think you could come close to the Bolt efficiency you experienced. You could do slightly better (than what my car would get) if you got the smaller battery since it would lighten the car.
I drive mixed freeway and city and use the AC a lot. I’ve averaged 4.0 since my last charge. That said, with your kind of driving I’d expect at least 4.5.
I get 4.8-5.2 m/kwH with my AWD sel i5. I drive 80/20 city to slower highways. if I am roadtripping, i definitely drop a bit but we have a Model Y also and its better than that. Either way, the difference between 4.2 and 5.0 is so negligible, Id never choose car based on that.
We have both, though the Bolt is a recent addition (bought used in August with 44K miles). We have just short of 10K miles on the i5 (LR, AWD, SEL), half of that accumulated on a 4,600 miles trip moving from the East to West coast. We get around 4.3/4.4 on the i5 and I see a little over 5 on the Bolt.
We headed off on a European trip just after we got the Bolt, so our experience on that is limited. I will say that the systems on the i5 are far more sophisticated than on the Bolt which we got to a) have a second car after the move, and b) to ensure that we stay within the lease mileage limits.
Cheers
We have a 2022 Ioniq 5 SEL, RWD, 19 inch wheels with about 78K miles on it. We routinely drive from Los Angeles to the Olympic Peninsula in WA state, we are snow birds. We get great efficiency in our little town of 10,000 people, but it drops a lot when doing 75 mph on I-5 and in Los Angeles. Also, efficiency really drops when it gets cold up north. But, that's when we head south.
Overall, we have an efficiency of 4.2 mi/kW.
Good question @i5maybe
I won't try to talk you out of seeking efficiency. To get the best answer to your question you would need to drive an i5 over the same 3000 miles with the same weather, road, traffic and topography conditions that get you the 5.2 kWh in your Bolt. The best car to car efficiency comparisons I'm aware of are run by Out of Spec Studios70 mph range test — Out of Spec Studios That comparison is run mostly at 70 mph, but the relative efficiency would be useful to estimate an answer to your question. In their tests, 2 Chevy Bolts ran 3.4 and 3.5 kWh respectively. A 2022 Ioniq 5 AWD with 19" wheels ran 3.1. So, it would be reasonable to estimate that the Ioniq 5 would be about 10% worse (4.68 kWh) on your 3,000 mile efficiency route than your Bolt.
My 2022 Ioniq 5 SEL with 19" wheels in Connecticut suburban driving will sometimes give me extended periods of 4.9 - 5.0 kWh over 200-300 miles, but it's easy for that average to drop to 4.5 even driving with an eye toward efficiency.
You will also notice on the chart that the Ioniq 6 is incrementally more efficient at 70 mph (as other posters have suggested). If you don't need a hatchback for your use case, an i6 might be worth considering.
My first hybrid car was a 2008 Honda Civic and that was such an underpowered, boring car to drive that I loved playing the hypermiling game with it, used to regularly get 3.6L/100km, driving 10km/h below the speed limit. Made a lot of friends on the highway ;-)
Then my first EV was a 2019 Bolt. With that one too, I drove it very efficiently, especially on longer trips due to the slow charging speeds. Now with my Ioniq 6 Ultimate AWD (not the most efficient), I mostly just drive it normally in Normal mode. At home, charging costs are so low, I don't bother to try and save 15 cents and on the road, it recharges so fast that again, driving it super efficient won't change much in the grand scheme of things.
Now OP if you enjoy hypermiling to death, have fun, it is after all the most efficient and cost effective way to do it but I understand what ARob says too.
It took me a while to get used to the I6 but now when I get back into the Bolt (now my wife's car), I really appreciate the I6 even more.
Good luck with your reflexion.
P.S. perhaps a different perspective on the efficiency numbers: my Bolt got an average of 21kWh/100km yearly due to the resistive heating in winter. My I6 got an average of 18kWh/100km for the first year.
Timely question as we just drove a 175 mile trip yesterday in our 2025 AWD Ioniq 5 Limited. From our home on Orcas Island, Washington, to the Seahawks game south of Seattle.
Rained on the way down, so wet roadways then, drove at freeway speeds (well, when we could), drove in Normal and not Eco mode, and temps were in the mid-60’s. Used HVAC for maybe 25% of the trip. Two adults.
We used 61% of our battery in these 175 miles, 39% remained when home. I have found that this car consistently outperforms the EPA rating, while the several Nissan Leafs I owned consistently underperformed.
For me it's more about making a smoother ride. I have no doubt that a careful driver can easily get the same efficiency in normal mode.
As a new "lessee" of a 2024 I 5 sel , I really have no idea how efficient my driving has been since November ! Not sure I'd even know how to check? But then again, after driving ice vehicles for 50 years, I never knew, nor payed much attention to what my avg mpg was! I'd just pull into a gas station when the tank got low and kept on driving. Now I just plug my car in at home when it gets low and the next day just keep on driving! Too many other things in this world to concern ourselves with than kw/hour or per mile or whatever the metric is when we're talking pennies not dollars. (just my 2 cents!).
And as far as tire size goes....I'm happy as long as they remain round!;)
@i5maybe - You have explained that your particular 'thing' about EV ownership is pretty much focused on how many miles per kWh you can achieve. To the extent of deliberating about buying a car that might not be able to match the figures that you have seen recently. And that's despite comparing apples with oranges over car size.
I tend to view such matters from a different perspective. Here in the UK I drive my Ioniq 5 AWD exactly as I have always driven my cars. I don't even consider whether the car is managing 3.5 or 4.8 or even 5.2 miles per kWh. It is what it is after any one drive whether thats in winter with horizontal rain up a mountain, or a bimble through English villages in summer. Again, it is what it is. And I'm unconcerned about the bald figures. Much of this comes from a previous life when I was involved in shaving pennies from processes.
I can't help applying costs to changes in methods.
For instance. Over 3000 miles, a car achieving a decent average of 3.5 miles per kWh would need 857 kWhs. And a car managing an excellent 5.2 miles per kWh would only use 577 kWhs.
That's a min and max figure for almost all modern EVs. The difference between superb efficiency and normal over the 3000 miles mentioned is 857-577 = 280 kWhs. I use an overnight tariff that costs me 6.7p per kWh here in the UK, and almost all of my mileage is at that figure. So, the difference between excellence and normal is 280kWh @ 6.7p = ÂŁ18.76.
Now, I realise that to some people, striving for an excellent economy is a cross between a good game and a fixation. But really? Less than $20 in three months. $7 a month. 20c a day? And that's the maximum difference between superb economy and OK? Made even more ironic when someone is prepared to spend $shedloads on changing rims and tyres in an effort to shave off another 0.1 figure from the average m/kWh.
Just buy the damn car. And drive it he same way that you have always driven cars. Then live with the figures, even if they are a tad lower than you managed in a smaller and lighter car.
We've put 10,273 miles on the '25 Ioniq 5 RWD we got in late June. On the road trip we just took, we averaged 3.3 mi/kWh.
In local driving we average about 4.4.
21 - 40 of 64 Posts
