Lighting Mods
1 reading
31K views 54 replies 24 participants last post by  Ben sk
Replaced all interior light bulbs to LED (vanity, glove box, and liftback). Added LED lights to interior, hood and liftback.
#3 ·
Do you have the draw type glove box? We do in the UK and it seems impossible to access the lamp with the draw in and I cannot see how to remove the draw!
#7 · (Edited)
Here are the links to the LED lights/blubs
Glove box: https://www.amazon.com/gp/product/B0186P1MUW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Vanity and liftgate/trunk: https://www.amazon.com/gp/product/B08FCX3FFN/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Hood/trunk: https://www.amazon.com/gp/product/B01LW2Q5AV/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Footwell: https://www.amazon.com/gp/product/B08G4Y5564/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The factory light housings are all snap in only so if you gently pry them from the sides, they will pop out. Be carefull as you can break them in the process of prying too hard.
#20 ·
I found some similar recessed spots on ebay
black trim would be nicer but only available in 10pcs. Those instructions are great though at it clearly tells you where to drill the holes.
#23 · (Edited)
I wired it so if the car is on, the lights are always on just like the ambient lights on the doors/speakers. I did this mainly because the LED consume very little power.
You can choose to take power from a fuse tied to the ignition. This way the light will be on when the car is on and off when off or simply add a switch.
#24 ·
You can choose to take power for a fuse tied to the ignition. This way the light will be on when the car is on and off when off or simply add a switch.
Could you possibly take pictures of how you wired it and post when you get a chance?
#25 ·
I can, but it's simple enough. if you want the light to stay on while the car is on, you can tap into the USB port wires. The two outside wires of the USB connector wires are your power and ground. Tap the center floor USB for the floor LEDs and the USB center console (above the wireless charging pad) for the center console LED.
If I have time I'll take some pictures. This might take a day of two.
#26 ·
Yeah man, whenever you get a chance I would really, really appreciate it! I feel I can do it but may need an explain it like I’m 5 thing haha.
just wanted to see where you mounted the LEDs, where you ran the wires, etc. did you use T Taps for the USB ports?
#34 · (Edited)
Very nice and clean, good job.
Keep in mind, we want better/brighter light but at the same time to consume the least amount of power. Most of the strip light uses over 1 amp. In this case, it probably doesn't matter because the light most likely will only be on for several minutes at a time.
#36 ·
I did change the front signal light to amber/white switchback led with aid of adapter I made. But fairly simple if you just want direct LED replacement. However, you have to find led bulb to draw at least just under 1 Amp or the car will hyperflash thinking it is a blown lamp. Below link to my mod.
#43 ·
If you try to replace the glovebox incandescent bulb, be careful. When I tried to pull the bulb, I accidentally broke the wires to the switch. The wires had about 1 extra inch and that wasn't enough to safely remove the bulb. Well now at least I got the LED bulb in and the light doesn't get hot (cause it never turns on).
#47 ·
I tried to get the glove box light fixture out today with no sucess. I pried the left side out but the right side would not budge, and it seemed like there was not sufficient wire length to remove the right side. Could someone that has successfully removed the light fixture chime in on how to remove it.
#51 · (Edited)
Thanks to everyone for their trunk lighting mod solutions.
I ended up blending two options with good results - the led light strip talked about here and another light strip talked about elsewhere.
I put the smaller light strip on the left side.
My ability to hide the top light wiring is... rudimentary.
