Hey guys,
I didn’t see a how-to on changing the reduction gear oil for the classic 28 kWh IONIQ ELECTRIC, so here’s my contribution to these forums.
Disclaimer: You are liable for your own actions. I’m not responsible for anything you mess up on your vehicle. If you are not comfortable, get it done at a mechanic shop.
A straight forward procedure and similar to changing manual transmission oil on a fossil car. If you’re 50/50 on doing this yourself then this should give you the confidence you need
Let’s start…
You need to lift the car off the ground and make sure the car is level and even. Either a jack(s) to lift up your car or use a ramp if your driveway is on an angle, you decide. Make sure to use the necessary axle stands and wheel chocks. In my case because of my driveway I used car ramps to make it level and axle stands on both lower control arms as a failsafe.
Now that you have the car lifted off the ground, crawl under it and remove the (felt?) under tray, which is secured by 12 plastic retainers/fasteners and seven 10mm bolts.
Depending on where you live, these bolts could be rusty and harder to remove. Mine were rusty so I soaked them in fluid film. Plastic retainers/fasteners can be removed by inserting a flat head screwdriver and popping the clip open or using a dedicated pry tool.
In my case extra time was wasted as some Hyundai dealer I went to in the past (I can only assume it was one of them) broke off a section of my under tray mounting points. So I had to waste time fixing it.
The fill and drain plugs are located behind the driver’s side wheel area. You do not need to remove your driver’s side wheel as there is plenty of room to work with.
Both black colored with yellow marker fill and drain plugs can be removed with either 24mm or 15/16” socket.
First loosen the fill plug and make sure it can be removed. You can then put it back in half way for time being so you don’t misplace it.
Second get your oil drain pan or bucket, whichever you have, and loosen your drain plug. Let all the gear oil flow out. Approximately 1.0-1.1 US quart of gear oil should be removed. Tighten back your drain plug to 25 foot-pounds with a torque wrench. P.S. You can get new washers (no clue about part number) or reuse your old one. I reused the old one as it looked completely fine and flat.
Time to put in new gear oil. Now completely remove your fill plug and use your preferred method to put oil back in via fill plug. In my case I used a 1L fluid transfer bottle pump. You could use those dedicated automotive fluid transfer syringes as well. Fill until you can see it at the bottom of the fill plug thread. Tighten back your fill plug to 25 foot-pounds with a torque wrench.
Before putting back the under tray, go drive around the block and check again for any leaks. Once everything is good, secure your under tray with all the12 plastic retainers/fasteners and seven 10mm bolts.
Your reduction gear oil change is now complete.
Here’s before and after of what the reduction gear oil looks like at 21,000 miles.
Let’s start…
