I'm curious.
I had same issue as already having had a 30 amp dryer type plug in garage that I had been using to charge prior car (Tesla). I just bought the SplitVolt also as it'll charge at 24 amp vs 16 amp on normal 30 amp chargers.I already had an existing 14-30 circuit in my garage, so, to leverage that, I ended up going with a Splitvolt 30 amp charger (24 amp capped output). It was affordable ($300) and has been reliable thus far (charge cable never gets hot). I use an RVMate splitter ($50) to share the circuit with my dryer. I’m careful to ensure the car charger isn’t plugged into the I5 when I run the dryer.
A low-budget solution, but it does the job.
Depends on your budget and how much you can "safely" spare from 200Amp panel.I am lucky enough to have a 200amp panel in my shop. I plan on putting a new subpanel in to support my charger. Electricity calcs are not my forte. What is the fastest charger I can install? It will be hardwired.
Check the label on the side of 120v charger. Mines has 120v input. The ones talked about have 120v-220v input on the label. Worst it will do is let the smoke out. The only voltage dependant part in the charge would be the relay that connects the power when the car signals it to. I would not do that without checking the insides of the chargerJust trying to get my math right. The cord that comes with the I5 will charge the Ioniq 5 at a rate of 3 to 5 miles range per hour. I thought I read on this forum that with a 120 to 240 adapter, you can plug in the cord that comes with the car, into a 240 source and that will then double the charging power so it could charge the I5 at a rate of 6 to 10 miles an hour. If 90% of the time, we drive 50 miles or less, that would mean that I could charge the car back to 80% in 5 to 8 hours, plugged into a 240 source.
Is that math correct in the real world?
I will get a level 2 charger, but knowing the above information strangely will help me make a few decisions.
Thanks
25 to 30 miles / hour is what I have read at 40 A.i purchased the Grizzl-e 40 amp to charge my RWD, can anyone reply how long does it take to charge your car?
50 amp breaker, having a plug installed below the box rather than hard wiring. Thanks!
We have been doing the same thing. At 24amps it will do from just under 20% to 80% usually just under 8hrs. If I want to speed it up I change the Grizzl-e to 32amps knocks a couple hours off. Do have 60amp supply to the garage but just a 40amp in the garage at the moment. Will be changing it to 50amp when I get around to it. If you are parked at home each night the 24amps is plenty. If you need a rush fill up just find a local DC charger for those two or three times a year you may need it.For our needs we don't need to charge fast and then get back in the car. We have the Grizzl-e set at 24 amps and that's plenty to get up to 80% overnight.
120v 12A = 6km/h = 1.5% per hour - OEMJust trying to get my math right. The cord that comes with the I5 will charge the Ioniq 5 at a rate of 3 to 5 miles range per hour. I thought I read on this forum that with a 120 to 240 adapter, you can plug in the cord that comes with the car, into a 240 source and that will then double the charging power so it could charge the I5 at a rate of 6 to 10 miles an hour. If 90% of the time, we drive 50 miles or less, that would mean that I could charge the car back to 80% in 5 to 8 hours, plugged into a 240 source.
Thanks
I would not try it unless it was 100% okay to do. I thought I read it was okay to do, but if it isn’t I won’t try it.120v 12A = 6km/h = 1.5% per hour - OEM
240v 12A = 12km/h = 3% per hour
Using SOC% is better, because range depends on air temperature, and SOC is always the same whole year.
Charger is not rated to 240V, but so far I did not see anyone who reported any issues. General consensus is manufacturer uses the same hardware for USA and Europe, only plug differs.
Disclaimer: you do it on your own risk, I do not guarantee anything.
Never run 16A in the regular 110V outlet. It is not safe to have continuous load over 80% of max load. You will destroy outlet and in wall cables if you lucky. Or it can be a house fire.Normally, I only drive 150 - 250 miles a week. I haven‘t seen the need to install a 240v circuit yet. (I got a couple of quotes for doing that. I would need to upgrade my electrical panel, so one quote was $1800 and the other was $3600 plus the cost of the EVSE.)
I bought a Vevor 110/240 Volt 32 Amp portable EVSE from Amazon for $200 and am running that at 16A on 110V. I can charge from 55% - 60% to 90% overnight (12 hours) and do that once or twice a week. Works for me.
That on 110 should be on a 20amp circuit with #12 wire. Should be tripping the 15amp breaker if it is drawing 16amp for any length of time. Would like to see the name plate on the side of that. Just looked it up. Has a nema 14-30 plug. So as long as the wall plug is proper should not be an issue. Though not impressed with the certification - says only the cable and car plug UL, nothing about the box itself.Never run 16A in the regular 110V outlet. It is not safe to have continuous load over 80% of max load. You will destroy outlet and in wall cables if you lucky. Or it can be a house fire.
Make sure that whichever circuit that you have that charger plugged in is on 20A circuit since 16A is more than usual 15A circuit.Normally, I only drive 150 - 250 miles a week. I haven‘t seen the need to install a 240v circuit yet. (I got a couple of quotes for doing that. I would need to upgrade my electrical panel, so one quote was $1800 and the other was $3600 plus the cost of the EVSE.)
Have you ever taken the wallbox with you on a trip, so that in essence, it is also a portable charger?Just would like to report that, after 1 month of usage, the Wallbox Pulsar Plus (Europe, with PowerBoost, 3-phase version) works as it should. FYI I set the car to 90% AC limit.
Just plug in and recharging starts within 3 seconds (Wallbox turns from green to blue). No need to use the apps (Wallbox nor BlueLink). When charging reaches the set limit, I do get a notification from both apps!
When notified or in the morning, just unlock the car (or lock and unlock) to free the charging port.
So far so good!☀
