121 - 140 of 160 Posts
Discussion starter · #121 ·
@andyfase Since the most recent update, the app doesn't seem to be working properly.
Try a remote refresh - i.e. press the date/time in the app to see how it updates. If that doesn't work, turn on Debug logs and message me and we can try to work out why. Its working fine on my side (as you know i'm in Canada) so perhaps its something specific to your account?
Re charge limits - is "80% AC/DC" the name of your charge limit?
Thanks for the quick response. I’ve driven the car to another city today and pressing the date/time row grabbed the current info. I thought the app would refresh automatically. Do I have to tap that row every time I run the app?
As for the charge level, I have these profiles in your app:
Discussion starter · #123 ·
You dont if you have the widget setup and "Enable widget remote refresh" checked in the settings. Then the widget will perform a remote status command based on the schedule settings (also options in the settings)
Outside of that the car hardly ever updates the Bluelink statuses on its own.
Finally - i've seen the Bluelink API response just be 100% wrong sometimes, nothing can be done about that except to do a refresh like i suggested.
Anyway TLDR use the widget and enable widget remote refresh if you want upto date info
Yeah, remote refresh has been on since the app was installed on my phone.
Hi. I installed the JS app, ran it the first time, and entered my credentials and other config info. I had to guess at my PIN. After it closed and I tapped the JS app again, nothing happened. Same after multiple attempts. Do you have error checking for wrong credentials and PIN? What now? Many thanks!
In settings, you can enable debug logging, and then review the logs (in the same folder as the script). The logs are fairly descriptive, so you should be able to find the response to the query, and it should indicate if the credentials were wrong.
Discussion starter · #132 ·
Yes but I have to be able to launch the app to get to settings, and the app isn’t launching. Ideas?
There is a reset script you can download at the same place you downloaded the main app script (link)
download and run that and click on reset all settings . This will reset all data for the main app and allow you to enter settings again and turn on debug logging
I haven’t tried but I don’t see why not?
Right, given this is merely a script, running in an Apple app, one would expect Apple has at least partially addressed any updates needed to Scriptable for the new OS.
The Public Beta is usually the first "safe" beta version for end users to tinker with. The first couple of Dev betas often have issues. I understand there was an update to the Dev beta already, maybe having to do with battery life. But the Public beta should become available in a few weeks and should benefit from things they learn from the Dev betas.
I am running the Dev Beta of iOS 26 and it is working however on the Control Center screen it does not show the correct icon when you resize the shortcut - it shows the Scriptable icon for all 4 shortcuts. Open to suggestions but figuring it will eventually resolve with 26 goes live.
Discussion starter · #138 ·
Sounds like a IOS26 bug - Im trying to avoid it tbh 😛 only thing I could suggest is checking for any kind of icon setting in shortcuts
Yes that was it. I was able to manually change the icon within shortcuts and it carried over to the control center. Thanks.
