81 - 100 of 107 Posts
I liked the dual camera installation and wish to order it too, just not sure if the fuse is micro 2 or mini?
I believe the vanity ones are also 31mm festoon - but I don't really use those so haven't bothered to look to check or change them. Might do at some point just so they're all the same! But the boot was the major one for me, daily use with dog!
Hello.
Have you changed the Vanity Mirror to LED's? How on earth are the lamps removed?
Ioniq 5 - Project 45
Hello.
The boot one came out by using a small plastic wedge to prise it out. I haven't looked at removing the vanity light as I don't really use those. But as the LED bulbs came in a pack of 2 and I have a spare I may look to see at the weekend if I can switch the driver side to LED. If anyone finds before an easy way to remove lamp let me know!
Same here! Ive done the boot but the vanity lights are well secured. Manual indicates the glass (Plastic) is removed and not the unit but there in very tight!
If anybody does find the best way please do post.
Vanity Lights (In the head lining covered by the Sun Visors) are easy to remove. Go to the side where the on / off switch is located, put your fingernail between the headliner and the plastic of the light and pull down, then slide to the side to release. It does not require much pressure and they will pull down. There is a metal spring clip that holds it in and at the other end is a fixed piece of plastic that goes above the headliner to hold it in place, you slide that side in 1st when putting back in. I did not look at or take the existing bulb out, just had a quick minute to do this.
couple of pictures for you, Hope it helps
Metal Clip at the switch end of the light (Pull down here, it will not require much pressure)
Rectangle Auto part Beige Automotive lighting Office equipment
This is the bulb in the light, Slide the non switch end in 1st when replacing and just push the end with the metal clip up till it locks back in place
Dvi cable Circuit component Automotive lighting Rectangle Electronic component
Regards
Phil
Regards
Phil
Cheers Phil,
Much appreciated.
Is the size 31mm?
Sorry, only had a minute or so to have a look and take the pictures so I didn't actually look at the bulb closely or measure it.......
Yes it's 31mm same as boot. Just changed mine, wow it's almost too bright with the same LED that I used for the boot light! But great very bright if you needed to stop and read something at night.
They look good.
Can someone do a definitive list of bulbs that are able to be swapped out for leds and which reliable bulbs to fit?
They look good.
Boot light and 2x vanity lights (under sun visor) - all are 31mm festoon
I used Eseastar 31MM Festoon LED Bulbs... Currently now out of stock at amazon (maybe all purchased by ioniq 5 owners!) They seem good quality and very bright, perfect for boot and good for vanity lights if you want a really strong light to read a map or book but maybe a bit bright if you wanted a softer light there.
Waiting for delivery of RWD 73KW Premium Ioniq 5
I used these Eseastar 31MM Festoon LED Bulbs... Eseastar 36MM Festoon LED Bulbs 12V-24V C5W 6413 6418 6461 6486X DE3423 DE3425 Canbus Error Free for Car Interior Trunk Light and more,6000K White : Amazon.co.uk: Automotive They seem good quality and very bright, perfect for boot and good for vanity lights if you want a really strong light to read a map or book but maybe a bit bright if you wanted a softer light there.
Sorry don't wish to be picky but you said they were 31mm but link is to 36mm Bulbs?
Well spotted thank you for letting me know, link now removed to avoid anyone ordering wrong one. 31mm now sold out and no longer listed, amazon defaulted to the 36mm when I copied the link from my order history. Maybe an idea to remove link from your quote above so nobody clicks it without reading the detail.
Ioniq 5 Project 45 in digital teal green
Regards
Phil
Works really well. Thank you. And looks so much better
Ioniq 5 Ultimate RWD + Tech + Eco GG
Just ordered these oneshttps://www.amazon.co.uk/Festoon-Re...+led+car+bulb&qid=1634402605&sprefix=3&sr=8-3
Hope I don't blow fuses installing them as I've done before!
Hmm what? I meant the black logo covers that I quoted. :D
As it was raining today, I will do it tomorrow, but at the end the task sounds really simple, some silicone (came with the covers) on the inside of the covers, and pressing them firmly on the logo and that should be it... (on the pictures here, I just put them on to see if they really fit and if I would like them)
