Built one up here in the USA as well - grand total of about $80 or so. I also had trouble with the terminals since the 12gauge extension cord I used is much smaller than the 6 or 8gauge the handle is designed for. My soldering iron WAS up to the task, so I just soldered to one interior side of the terminal (also after removing the O-rings, which I suspect are butyl and would melt).
Interesting side note here in the USA where the J1772 plug has a latch on it, which is held locked in place by the car. You DO need the power button between CC and CP, because if you just keep them shorted together, the car will never unlock the port and you'll never be able to unlatch the handle.
However, the latch on this unit is plastic and quite floppy, so you can press the thumb lever down all the way to hit the latch switch, even if the latch itself is still locked in place. Doing so shuts off power output (as a safety), and if power output is off, the port can be unlocked. So with the power button ON, you can still unplug this particular handle by pressing the latch hard, then unlocking the car, whereupon the car will unlock the port and the latch will spring up and open. Kinda dumb and not particularly useful, but I think fun and interesting.
