1 - 3 of 3 Posts
Hi,
Someone tried or know if it is possible to mount whole led headlamps instead of normal one?
I'm not interested of changing only bulb but whole headlight. (the old one are crashed)
It is needed to buy some extra dc converter or some levelling sensors?
Thanks in advance
Ok i'm confused are you saying you headlight got damaged? Thus you would like to know if the Full L.E.D housing that usually comes on the EV can work in your hybrid. ?
If so the Xenon or LED honestly should work as the connector seems the same from my research what differs is how the wiring breaks out for high/low or the different bulb designs.
I have seen the first gen to 2019 model with the 2020 LED headlight housing so it can be done. what im not sure is if its plug and play or needed any extra.
hope i helped
I have no idea how to make that change, but you need an automatic headlamp leveler. In contrast, xenon headlights do not need them since they are low power. I have exchanged my halogen headlights for original xenon headlights.
1 - 3 of 3 Posts
