1 - 20 of 68 Posts
Torque Pro is an application for Android tablets and smartphones that interfaces with OBD2 enabled devices (via bluetooth or USB) and provides visual feedback in the form of gauges and digital readouts of the various parameters and values provided. Torque Pro is normally used with ICE cars, but by adding new parameters it can also be used by the IONIQ 5. The advantage of Torque Pro is that it is really flexible in graphing and displaying data.
On GitHub Torque Pro PIDs for Kia Soul EV, Kona Electric and E-Niro EV are posted by @JejuSoul here: OBD-PIDs-for-HKMC-EVs
I used the Kona and e-Niro PIDs in the above GitHub link as base for the IONIQ 5, because we know that also for e.g. free Car Scanner Android App the Kona settings work for a major part. The Kona PID's I started with can be downloaded here.
I added the missing Cell voltages (93 till 180). I adapted some calculations, because the IONIQ 5 has a larger battery pack and torque (72 kWh and AWD). Added 16 battery temperatures and Tire Pressure/Tire Temperature, Speed and Odometer.
Short instruction on how to read the csv into Torque Pro is described here.
The latest TorquePro PIDs for the IONIQ 5 with 74 kWh and 77 kWh battery can be downloaded here from github, thanks to @Esprit
I made an update to the IONIQ 5 PID's and made new screenshots with a nice background and information divided into several pages.
Screenshot of Tires Pressure, Tire Temperatures and Battery (Pack) Temperatures and some other related interesting information.
Automotive tire Yellow Font Line Screenshot
Screenshot of overview information. Note that the RPM2 will be shown when the Front Motor is working, RPM1 is for the Rear Wheel Motor. A Histogram of the Energy Power is also shown, e.g. handy if you are driving.
Font Screenshot Electronic device Technology Games
And a screenshot of Charging related measurements. Note that you can design your own pages with the information you want with Torque Pro.
Font Line Audio equipment Engineering Screenshot
Screenshot of Cells 1 till 66
Product Rectangle Font Line Symmetry
I hope we can improve the PID's and even add missing PID's for the IONIQ 5. So help is appreciated.
For people who want to have the same layout/background as in this post. Normally you have to insert all the available measured values PIDs as displays yourself.
You can also import the layout, but if you have an Android device with a different resolution you will still have to rearrange the elements. My cell phone has a resolution of 2300x1080.
Make sure to import the downloaded PIDs from GitHub: "TorqueIONIQ5AWD74kWh.csv" or "TorqueIONIQ5AWD77kWh.csv" (dependent on your battery size) in Torque Pro (see description here).
As a background I have set:
Tire Vehicle Wheel Car Automotive tire
As a Theme I have set:
Transparent theme
A theme where dial backgrounds are transparant
Ian Hawkins
The exported dashboard can be downloaded here.
The background and dashboard can be imported into Torque Pro.
Apps for reading out the OBDII supporting IONIQ 5:
- Torque Pro (Android)​
- Car Scanner ELM OBD2 (Android and Apple)​
- Soul EV Spy (Android)​
- EVNotify (Android and Apple)​
- ABRP (Android and Apple)​
- EV Watchdog (Android)​
Discussion Starter · #2 ·
First post updated:
~20210908 V2 Fixes and new features
~Fixed tire pressures
~Fixed Odometer
~Removed Battery Module 06 Temperature
~Shortened Short names of several formula's
~Fixed CALC Average Battery Module Temperature
~Fixed CALC Average Cell Voltage
~Added estimated charging time from current SOC to 80% for 2.3/3.7/7.4/11/50/100/150/175/350kWh chargers using evdatabase 10% to 80% estimations.
Discussion Starter · #4 · (Edited)
I am still missing Battery Temperatures and think currently some are wrong too. Maybe people can help solving the puzzle.:unsure:
There are 360 Cells, 2 x 180 Cells, 8 different Packs, 6 Packs of 4 Modules and 2 Packs of 3 Modules (30 Modules total).
I suspect each Pack has 2 temperature sensors, so 16 in total.
I suspect 21 battery related temperatures in the readouts. See screenshot:
Rectangle Font Technology Pattern Electric blue
I have also another readout:
~T01 = 20 C Battery Max Temperature?
~T02 = 18 C Battery Min Temperature?
~T03 = 20 C Battery 1 Temperature?
~T04 = 20 C Battery 2 Temperature?
~T05 = 20 C Battery 3 Temperature?
~T06 = 19 C Battery 4 Temperature?
~T07 = 19 C Battery 5 Temperature?
~T08 = 19 C ?Battery Inlet Temperature?
~T09 = 19 C ??
~T10 = 19 C Battery 6 Temperature?
~T11 = 19 C Battery 7 Temperature?
~T12 = 18 C Battery 8 Temperature?
~T13 = 18 C Battery 9 Temperature?
~T14 = 18 C Battery 10 Temperature?
~T15 = 18 C Battery 11 Temperature?
~T16 = 19 C Battery 12 Temperature?
~T17 = 18 C Battery Heater Temperature 1?
~T18 = 18 C Battery 13 Temperature?
~T19 = 19 C Battery 14 Temperature?
~T20 = 18 C Battery 15 Temperature?
~T21 = 19 C Battery 16 Temperature?
Therse are the Torque Pro Pids:
Code:
000_Battery T01,T01,0x220101,Signed(O),-40,80,C,7E4
000_Battery T02,T02,0x220101,Signed(P),-40,80,C,7E4
000_Battery T03,T03,0x220101,Signed(Q),-40,80,C,7E4
000_Battery T04,T04,0x220101,Signed(R),-40,80,C,7E4
000_Battery T05,T05,0x220101,Signed(S),-40,80,C,7E4
000_Battery T06,T06,0x220101,Signed(T),-40,80,C,7E4
000_Battery T07,T07,0x220101,Signed(U),-40,80,C,7E4
000_Battery T08,T08,0x220101,Signed(AO),-40,80,C,7E4
000_Battery T09,T09,0x220101,Signed(AS),-40,80,C,7E4
000_Battery T10,T10,0x220105,Signed(J),-40,80,C,7E4
000_Battery T11,T11,0x220105,Signed(K),-40,80,C,7E4
000_Battery T12,T12,0x220105,Signed(L),-40,80,C,7E4
000_Battery T13,T13,0x220105,Signed(M),-40,80,C,7E4
000_Battery T14,T14,0x220105,Signed(N),-40,80,C,7E4
000_Battery T15,T15,0x220105,Signed(O),-40,80,C,7E4
000_Battery T16,T16,0x220105,Signed(P),-40,80,C,7E4
000_Battery T17,T17,0x220105,Signed(X),0,80,C,7E4
000_Battery T18,T18,0x220105,Signed(AN),-40,80,C,7E4
000_Battery T19,T19,0x220105,Signed(AO),-40,80,C,7E4
000_Battery T20,T20,0x220105,Signed(AP),-40,80,C,7E4
000_Battery T21,T21,0x220105,Signed(AQ),-40,80,C,7E4
I do not know the meaning of T08, T09 and T17. The others I am pretty sure of, because the Max, Min and 12 Pack temperature sensors match exactly the IONIQ 28 kWh EV PIDs.
You might want to check up on the Ioniq 5 - Battery Overview Thread.
Jaz + Giora had gone over the battery size/packs/modules configuration on page1 on that thread.
If you are working on a general Torque PID file for I5, you might want to take into consideration the probable 2 extra battery modules expected to be supplied in the US models.
(8x4 in US) vs
(8x3)+(6*1) in RoW so far.
The codes for those modules are probably already accounted for.
Sorry to hijack a little here.
Extra question: I plugged in a OBD2 module yesterday (vGate icar pro BLE4), but using an ios app (OBD Auto Doctor, and the unpaid version only output GPS speed :/
If Torque Lite/Pro is only for Android, would you have any recommendations on the evil iOS side ?
Most apps seems to need to be paid. Battery temp looks curious to monitor, so that is a minimum.
OBD Fusion costs 10 bucks. EVNotify ?
I could look for an old unused android phone in the house somewhere of course too :)
@Zuinige Rijder: Just installed it. Will check the app next time I get in the car :) Hope to get more than just GPS speed. Even just the basic sensor readings would be good, and as you are obviously also interested, the battery voltage/temperatures. I'm itching to see how hot they get during a fast charging 350kw station vs idle temperature.
update: car scanner connects fine. Less info than what you are showing on torque. Thanks again for the tip!
Discussion Starter · #9 ·
~20210910 V3 All known battery temperatures
~Added 16 battery pack temperatures
~Removed inlet temperature
~Removed heater 2 temperature
~Shortened names even more, do not put e.g. T in shortname when the symbol is C, Same for V and A.
~Fixed Indoor and Outdoor to properly show Celcius
Black Yellow Font Screenshot Automotive tire
Tire Light Product Automotive tire Motor vehicle
Light Font Line Engineering Electronic device
Discussion Starter · #19 ·
The developer of Car Scanner ELM OBD2 has incorporated my Torque PIDs for the IONIQ 5 of the first post in that App. Now you can choose IONIQ 5 in the settings as vehicle profile in Car Scanner. Note that the developer did not take the latest version, because there are still 184 cell voltages instead of 180 cell voltages in the App.
OK, so I have the app installed with the Ioniq 5 profile chosen but the dashboard etc look generic and nothing like your views. How do I select your views? I am running on Android if it makes a difference.
Thanks
CJ
1 - 20 of 68 Posts
