61 - 75 of 75 Posts
Thanks for giving it a try. Would you mind emailing the soulspy.log.2019XXXX.txt files recorded during the two attempts
On my latest attempt I got cell map to show up, so there is some progress. It took a bit to get it populated.
Interesting fact from it: The temp difference causes cell voltage variations, most likely relative to the physical locations of the cells inside the battery. This is good visualization and perfectly explains why the voltage differential exists between cells. Oh, the battery is perfect, kudos to LG & Hyundai!
Hello guys ! Have a question for you ! What ODB are you using on your Ioniq EV and are you keep it always plug in !? I want to use to the EVNotify app and Torque but want to make sure my odb is compatible.
Got my adapter (mini ELM327) and it won't connect to the ECU on my IONIQ. I tried it on a GM truck and it works great. Any suggestions? What protocol does the IONIQ use? Tks.
I already own a 'OBDLink LX' because the guys that made the brilliant app 'Hybrid Assistant' recommended this one. Now I read that it is not recommended here. First experiments show it seems to work. It also supports Torque's high speed mode. I haven't driven with it yet, because I still need to find or make a dashboard that fits my Samsung S7 screen, but is there anything I should look out for? Any test I can run to confirm or deny full compatibility?
Hi,
I have Torque Pro installed on my head unit. Both Torque Pro and ABRP were working fine until yesterday. I did everything according to these instructions and did not install any boot loader:
The list of apps installed is as follows:
- Total Commander
- SoundAbout
- EasyTouch
- Torque Pro
- Vanced Youtube
- Chrome
It started with Torque Pro showing "Faulty OBD Adapter" on the side of the screen and then some weird values showing in Torque, like the battery temperature at 8 degrees C and the SoC at 0%.
Now when I start the car, the multimedia unit stays at the Hyundai logo startup screen and doesn't react to anything anymore.
I've tried
- shutting down and restarting the car
- Pressing the reset pin next to the volume button
- Attaching a keyboard to the USB adapter and pressing Ctrl-Alt-Del, the screen flashes and then the logo comes back up again.
So, have I bricked my multimedia system?
Does anyone else also have a unit that's stuck at the Hyundai logo? If so, how did you solve it? Is it possible to re-initialize the unit somehow or did you have to go to the dealer to have it replaced?
Kind regards,
McTrex
Discussion Starter #69 (Edited)
The 'OBDLink LX' won't work with the Soul EVs TPMS sensors. see below. You don't need this for the Ioniq, so you should be fine.
Yes. please test the TPMS. we have had reports that it did not work with the 'OBDLink LX' . But perhaps that problem has now been fixed.
Specific reason -
"The device does not consider 7D6 as a standard CAN message (only from 7E0 to 7E7) so it does not generate a CFC (Continuation Frame Control)..."
see - recommended obd2 adapter? - Page 2 - Kia Soul EV Forum
Discussion Starter #70
I've tried
It seems you have bricked the multimedia system. yes.
Have you tried removing the OBD2 adapter, have you tried disconnecting the 12V battery for a few minutes.
These are long shots, but are worth a try.
If it is bricked you will have to take it to Hyundai, and they will re-install the original software.
It will be under warranty, they will have no idea why it failed.
The navigation computer is an android system. Ctrl-Alt-Del should have no effect.
On an android tablet the way to re-install software onto a bricked system is to push a combination of buttons eg 'Power', 'Home' and 'Vol Down' together.
This will cause the tablet to enter 'Download Mode'. Then you can install software from a PC using programs like ODIN.
How you could do this in your car I have no idea.
Hence I suggest taking it to Hyundai.
In adding the PID to Torque I cannot see Hyundai in the list of vehicle manufacturers....
I only see:
Chrysler/Dodge/Jeep/Mercedes
Emerald M3D ECU
Orion BMS
Other
Pontiac / GM / Opel / Vauxhall
Prius Gen2 (2004-2009)
Prius Gen3 (2010+)
Prius PHV
Anybody a suggestion?
Discussion Starter #74
I started this thread 3 years ago in April 2017.
Hyundai and Kia use the same BMS in all their electrified vehicles. (EVs, PHEVs and HEVs).
The 27kWh Kia Soul EV is the only one that shows Max and Min Det values.
Until now this car (27kWh Kia Soul EV) is the only one that we are able to work out the SOH with any accuracy.
It is also the only car we are able to work out the capacity of the 'early year's buffer'.
I am hoping that some of you will begin posting data for the state of health SOH of the battery this spring.
Not because I want to see heavily degraded batteries, but to know that the value we call SOH in Torque is working.
For instance if the car were losing 3% a year and the 'early year's buffer' was 10%, then it makes sense that for the first 3 years the SOH would remain at 100%
But now in the 4th year we should begin seeing lower values.
Also if the experience of the 27kWh Kia Soul EV is replicated a new group of users will begin sharing their values this year. (Buyers of ex 3-year leases).
I expect values seen by this new group to be very different from the values published by the long-time users of this thread.
61 - 75 of 75 Posts
