I have played with the easy entry setting on my vehicle, but no matter what I do, the seats do not go back far enough unless I am in the vehicle to manually adjust the seats. My memory buttons will simply not work when the car is off. I did send an email to Hyundai's customer service. Still no word back but I'll post the response if I do get one. Thanks. It's nice to know there is a possibility this might work some day.
I also thought that the memory buttons did not work with the car OFF, but I was wrong. I learned that each profile can separately program each memory button. Note that saving the seat position involves holding in the button a few seconds. Recalling the saved seat position involves pushing the button once briefly.
Try this;
With the large person's profile chosen and the car on, save his driving seat position to memory button 1. Make sure the display confirms that the seat position has been saved.
Then move the seat completely back and save it to memory button 2.
Turn the car off.
With the smaller person's profile chosen and the car back on, save her drivering seat position to memory button 1.
Return the seat position to her driver's position by pushing button 1
Turn off the car. The seat should move back a bit if easy exit is chosen
Lock the car.
Unlock the car
With the car off, push memory button 2. The seat should move completely back. Mine does.
Turn the car on. The seat should try and return to the smaller driver's normal seat position.
Try and change the profile quickly to the large person's profile before his knees get crushed.
if this doesn't work, have them tell you how you're supposed to get into the car with the seat all the way forward.
Good luck
