1 - 20 of 23 Posts
Does the SatNav have a speed camera warning facility (UK spec)? - I've not been able to find anything trawling through the menus and Speed Cameras don't appear to be a POI category either....
yep, you get a ding dong about 10 seconds before you go past a camera location that has been notified to the system
you need to have live services set up and the car tethered to a phone or car mifi so it can connect to the internet over wifi to get live traffic and camera
there is an option in one of the nav system settings to turn on speed camera notifications, it is off by default as speed camera warnings are illegal I some countries but not the UK
I think it is press the cog button 2nf from right under nav unit then go into the nav system setting and its in there if my memory is correct, if you are still having problems let me know and I will have a look on mine tomorrow
I think you may have to have your nav system tethered to your phone before the option comes up
Ah...I haven't gone into the settings when the phone is tethered . I'll check it later ;)
I can confirm if you don't have the car tethered to a phone for internet access / live services the option for speed cameras don't appear
just checked when I took my car out to get some cold drinks
\\\saved me the trouble then thanks ;)
Is it possible to put your own POI speed cams on SD ?
Hi, Does somebody know if it is possible to put your own POI. speedcam's to the SD and will it work on the spot ?
once connected tethered, can you download local locations of speed cameras so you don't have to use data all the time? or must it be tethered?
Mine is connected up to my phone and shows the roads in red where there is heavy traffic but does it have the ability to redirect you around it, like Waze does? I thought it had one day while travelling to Liverpool, M6 was red and it took me a roads the whole way, I thought how clever, until I looked in settings and realised I'd had it set to avoid motorways.....
Also, has anyone used waze via Apple car play? Apparently it's possible to load the app on the cars display? Not tried yet.
It can do it automatically. Alternatively you can manually request a recalculate from the button on the traffic info screen.
Reactions: TKGDee
1 - 20 of 23 Posts
