1 - 5 of 5 Posts
Morning All from the sunny Isle of Man.
My IONIQ Premium SE Hybrid has had the red and amber brake warning lights (with the exclamation) marks come up on the dashboard -- but only if you go above around 35 MPH.
I've dropped it into the garage for them to check it out, but wondering if anyone else has had this?
Cheers!
Check you braking fluid and parking brake. If no solution navigate to the nearest Hyundai dealer. Minimize driving in your car , or be extremely careful!
Reactions: clamdiver
As Rene says check your parking brake and brake fluid . I had it coming up on mine intermittently , topped up the brake fluid has come back since
We had this too, manual said go to dealer but in fact it was just low brake fluid. Probably as a result of the brakes bedding in, suggesting that the car was delivered with the minimum amount of fluid, as no leaks were found.
1 - 5 of 5 Posts
