1 - 20 of 33 Posts
Has anyone looked into and found a 2" receiver hitch for the Ioniq? I have no intention of towing a trailer of course, this if for mounting my bicycle rack. I have a 2" receiver on my Toyota Prius (that will be sold when I buy my Ioniq) and it works great, though I get lots of comments about what I could be towing with a Prius :) The hitch mount bike rack has a MUCH lower gas mileage and performance impact than putting bikes on the roof.
Welcome Mtsarpilot
please introduce yourself over on New Member Introductions - Hyundai Ioniq Forum
a number of members have looked into tow hitches for bike carriers, currently the Ioniq is not rated for towing, but I believe several towbar manufacturers are looking at making a tow hitch for bike transport only, so far nothing has been confirm
look at http://www.ioniqforum.com/forum/313-exterior/3049-bicycle-rack.html
https://www.google.com/url?q=http:/...409-attaching-bike-rack-trunk-us-boot-uk.html
Thanks bluecar1. That's pretty much what I suspected. The car design is too new and the market for such a hitch is probably quite small so it will take a while for someone to create one. I'll keep watching out for a solution.
Yes, I too am interested in putting a receiver hitch on my Ioniq for the sole purpose of transporting my bicycle. Please let me know as soon as one is available.
Hi, I'm new to the forum. I had a 1 1/4" hitch on my Camry , now buying a 1 1/4" hitch from carid dot com, $112 free ship. I intend to buy a cheap 1 1/4" to 2" adapter from Harbor Freight, works very well.
No hitch yet in the US. They were quick to get one out for the hybrid, I'm not sure what's taking so long with the EV. :(
Discussion Starter · #7 ·
I'm going to guess the limited number of Ioniq EV's delivered in the USA makes it a very small market. With so few cars then think about the limited percentage of those owners that are looking for a hitch and the manufacturers are probably not seeing it a viable market worthy of their investment yet.
Also the rear end of the EV is constructed differently to the HEV/PHEV.
I just Googled ("Can I put a trailer hitch on Hyundai Ionic Hybrid") and there are at least two 1 1/2" hitches available. (And this forum post obviously)
www.etrailer.com/hitch-2017_Hyundai_Ioniq.htm (shows 2 hitches but they might actually be the same one). Note that you also need the other parts (mount, ball, clips, etc).
Cross referencing with the U-Hall site, they're selling the same one for the 2018:
Obviously this would also need the ball mount, ball and clips. I don't know if the wiring is needed for bicycles or not. Maybe that depends on your location.
I'm not affiliated with any of the above. I just bought a new 2018 Ioniq and am an avid bicyclist. :nerd:
Discussion Starter · #13 ·
I just installed the Curt hitch purchased from etrailer.com. I'm a mechanically handy type person and engineer that does a lot of tinkering and has all the tools to install. It took me about 1.5 hours to install, 90% of which was by myself. I had my wife hold one end of the hitch while I put the first bolts in the other side. The rest was by myself. Half the time was jacking up the car, bolting in the hitch, lowering and cleaning up everything. The other half the time was doing the cut out of the plastic material on the driver's rear side corner that has to be trimmed for the hitch. I am meticulous and wanted to do remove the least amount of material so carefully measured, remeasured, and engineered the cutouts to leave the most material in place. Particularly did not want to cut off the second screw mount point of the plastic. The cutout diagram showed a simpler cutout but would lose this mount point to hold the plastic piece back in place. So even being detailed about it, it was an easy installation.
I went with the Curt over the Draw Tight because the two ends of the crossbar are at different heights in their attachment to the mount brackets. This will give a touch more stiffness in the downward twist applied by tongue weight. At least that's what me and another mechanical engineer felt. So was worth the extra $20. On my old Prius I had a problem with the hitch bending with the bike rack which forced me to weld on another support bar. I wanted the strongest solution that was available.
In the end, both of these are Class 1 hitches. 200lb maximum tongue weight. tabletguy, you have not indicated where you live. Assuming the USA for now. No wiring is needed in the USA to put a hitch mounted bike rack on. Though if what you put on the rack obscures your tail lights, the police may have a discussion with you.
The car is not rated for towing, so use it for racks only. I imagine you could stress the engine in ways it is not intended if you tow with the vehicle. The regenerative braking is certainly not designed to take the load of a trailer pushing the car forward.
Hitch Inlet End and Bumper
I just bought and had installed a Draw Tite trailer hitch and am concerned that the pinhole on the inlet tube is about 3inches back from the end of the bumper. I have ordered a bike rack, Duat Beta, which will be delivered tomorrow and am concerned that there will not be enough clearance for the rack. I particularly like the Duat because it was compact and low weight.
I would really like to hear what other people have bought and experienced.
Thanks!!
Discussion Starter · #15 ·
I installed the Curt hitch and use a Kuat Transfer 2 bike rack. Similar to what you are describing, the hitch and hitch pin are well forward of the back of the hitch. Even so, my rack is well positioned on the car. When it is folded up, the hatchback misses it by about 1/2 an inch. Perfect fit.
I have the Curt installed and use a 1UP rack (made in Wisconsin). It only contacts the tires on the bike and is adjustable, in and out, at the receiver for clearance at the hatch when folded. I can post a photo after the sun comes up :)
mtsarpilot: Interesting that you put a 2" hitch on your Prius. I'm guessing that it was a 2010-2015, in which case the only 2" hitch I could find for my 2010 was the TorkLift. It was expensive ($350) and weighed a ton! It was so heavy that I ended up not using it at all and selling it on Craigslist for $100! I, too, really only wanted to carry bikes on the hitch. We're looking for something for the new Ioniq but it will be a 1-1/4" hitch with a 2" adapter for the bike rack.
Thanks!
I live in Minnesota. Sorry I didn't mention that.
My thought was that I might want to tow a light sailboat, and so I had the wiring installed. However, I agree it's not needed for a bike rack. And I agree the 1 1/4" receiver isn't suited to a larger tongue weight. That effectively means a maximum of two bikes on the rack as far as I know. I can get 1 or two bikes inside as well if I take off the front wheels, but I don't want to be bothered with that! haha.
The only downside for me so far is that the back bike rack seems to allow more dirt to stick to the back of the car, probably from the different aerodynamics pulling dirt from the air :(
1 - 20 of 33 Posts
