1 - 20 of 31 Posts
Hi all,
Thought it would be good to list all recalls/common issues/upgrades available so far at one place. This will help me push the dealer to get these checked/addressed before delivery and sure will help others too.
Some items I know of:
1. Media unit replacement / recall
2. Brake binding issue
3. Squeaky noise from front door (both?)
4. Software upgrades
5. Battery issue - PCB?
6. The Netherlands for EV models: The charging cable (normal, not the trickle charger) had to be checked the last time I had my car in. (pmideld)
7. Any others??
Pls feel free to add / correct to the above list. Thanks. 0:)
issue 1 :- only affects early models less than an hour in workshop (min was abut 30 minutes)
issue 2 :- return spring replacement on rear calipers, currently a known issue, waiting to see if it get turned into a recall
issue 3 :- squeaky door is an easy fix, a bit of silicon spray / rubber lubricant applied to the big bit of rubber on the inside of the door just in front of the wing mirror and the paint it closes onto
issue 4 :- currently only software upgrade is to fix carplay echo issue, (also includes map update to nav sytem)
issue 5 :- battery issue, current fix is to replace PCB in fuse box which contains the fuel pump sensor / control circuitry (waiting to see if it turns into a recall)
no other issues so far
There is another recall, at least for The Netherlands for th EV models: The charging cable (normal, not the trickle charger) had to be checked the last time I had my car in. There seem to be around "less good" ones (like my dealer said it).
I also have the squeaky door at the driver's side.
Wow I'm so lucky... don't want to jinx it but I've had no problem with mine at all. No squeaky doors, dodgy batteries or brakes.. and I e already put 4000 miles on it.
Let's hope it stays that way! >.<
Reactions: Peter
ou've gone and done it now haven't you ? ;)
added to list at top of thread, squeaky door easy fix, see 2nd post in thread
2017 Ioniq EV 28kWh
EV Ioniq 5000km driven now here and the only thing I am gonna ask for in the service at 15000km is the issue 2 :- return spring replacement on rear calipers.
get a map update / media unit firmware update to cure the carplay echo issue
2017 Ioniq EV 28kWh
Apple Carplay is not really important for us Android users :)
But yeah, I view the map updates as something that should be installed automatically on each yearly service visit.
map update, roads not updated since november 2015
I had the recall for the media center. To my surprise all settings were lost. So no more favorites. Don't think you can save settings. Should be on the todo list for Hyundai.
I waited for the latest map update before going to the dealer for the recall. The new map is at least two years behind. Rather surprising.
I use a Ford focus for work. Then you feel the quality of the Ioniq satnav. It is much more responsive and better designed. The Focus is very slow and laggy. To my surprise the Ford system did a full restart while I was driving!
I could say something about the high petrol consumption of the Ford. But I was driving in Germany. A bit faster than I would with my Ioniq0:)
media unit recall is a complete swap on the media unit, not just a firmware upgrade,
there don't seem to be any way to save data off the unit prior to swap
also all map data (previous destinations, favourite places) as well as Bluetooth pairings etc
There are reports of faulty chargers or chargeports...
If its more or less than other brands i dont know, i know it happens sometimes, to all...
Ppl cant charge on CCS or Type2 or at home.
Ppl are trying 3 different ways of charging and no go.
No confirmed solution or why it happenes, cars have to go to dealer. "Dead charger"
It can be a fysical thing that cabel cant lock into chargeport on car, or the onboard-charger..
do you have any links to the charge issues for the EV?
Well, its mostly norwegian forum and facebook i have seen it.
Norwegian : A person who cant get the cabel to lock to car for charging, have tried all 3.
Gets 3x "bzz" (cant llock to cargeport)
Ioniq lader ikke
Norwegian : A person who can not get home-charger to work, also tried a Salto charger at the dealer, didnt work.
Had to change ocb(?), hole brai/main part, cost almost 10.000euros (ofc covered by hyundai)
Bilen lader ikke
1 - 20 of 31 Posts
