What?
Hello everyone! I decided to mod my Ioniq 5 a bit and install a Gentex full display mirror and see how it would perform. I managed to find the mirror iteself on eBay for much cheaper than usual and figured It'd give it a shot. At the same time I wired my Blackvue DR750X-3CH Plus dashcam. The model number for the mirror is GENFDM3LN.
My main goal with all of this was to have as much be reversable as I could. Some of it, like mounting the rear facing camera for the mirror, will not be reversable in a way that doesn't damage the camera housing. The car would be fine, and only my pride would really be impacted.
I have a limited trim so I made use of the wiring for the homelink mirror and the dongar adapter. I snipped the USB part of the adapter off and added some connectors so I could in theory get it back to previous function if I wanted to. I think this is definitely doable without the homelink mirror, but it was easier to get power to the mirror this way. I think if you had to run wiring for power you might want to run the pwoer and video cables separately (which is recommended in the manual). The process of running wires to the rear should be similar in that case, just on the passenger side.
I'll try to include some images here, but for more details this gallery is your best bet:
Video of a mirror test:
Verdict
I had fun planning this out and installing everything. I went slowly and took my time at each step as I was pretty concerned about damaging my new car. In the end the mirror works well, but I learned that I am indeed more impacted by the dreaded presbyopia than I realized. It takes my eyes a second to adjust to the video on the mirror which can be a bit dissorienting when in motion. It's not the worst, and it is better than nothing during heavy rain, but it should be a consideration if you are over 40ish years old or otherwise have eye issues.
One thing I don't have is a good image/video of performance during the rain. During the initial part of the rainfall the camera works very well. The enclosure prevents any shadowing or reflection and I placed it up high enough it doesn't get a lot of water in the way. After a while it does seem that the area will get wet enough that the occasional drop will be in front of the camera. For the most part this doesn't pose a huge problem as you can still see more of the road than you'd be able to otherwise, but it is notable.
Alternatives
When I was reasearching this I did come accross some posts where people were using mirrors from other vehicles in a much more DIY approach. This could work in our cars as well, but I didn't want to hack at my spoiler to find a spot for the camera. In general the cameras are all coax but the GM ones are larger and don't have great mounting options in our cars.
I came accross options like GM part number 13536995, which is an auto dimming full display mirror you can find on ebay pretty often. You'd then need the proper FAKRA cable and camera. I think GM part number 23295906 could work as the camera, but the aspect ratio might not be ideal for this case (I haven't tried). GM part number 84567388 might be better, and if you can find it for cheap you get two cameras to try.
I heavily considered this but, again, I had no idea where to put the camera. I don't know if there are decent enclosures or other cameras that could work in this case.
This is a fun read:
https://www.reddit.com/r/S2000/comments/th895k
Verdict
Alternatives
This is a fun read:
