1 - 9 of 9 Posts
Hi,
I would like to confirm the correct working of the ventilation system of my Ioniq EV.
Normally, it’s set on ‘auto’ but sometimes I want to control the airflow myself. So I press the button below:
32917
For a brief moment, the setting of that button is reflected in the display (13), the airflow with person-icon.
32918
But after a few moments, the icon (airflow with person) goes off and the windscreen/auto-icon goes on.
I confirmed that the airflow gets set to the setting I selected, but why I isn’t that reflected in the display all the time? Do you experience the same?
Thanks for your time.
Turn Auto off first. I never use it, and the icon you show displays the position I want and changes everytime I press the button. I can hear the vents in the dash opening and closing as I scroll through the selection.
Try turning the ADS off. The automatic defog system will take over when the sensor behind the rearview mirror senses to much humidity.
2019 Ioniq Electric, 2022 Ioniq 5 Limited (in transit)
The system in the Ioniq EV is very good. For economy sake, I never have the fan above 2 bars. That seems to always keep the cabin right for us. HVAC is the largest energy draw after the drivetrain. Turning auto defrost off is a good choice for economy as well. Many times a little warm air will defrost well. You can still manually engage defrost with AC if you desire.
Discussion Starter · #6 ·
Thanks. But what I’m trying to figure out if it’s normal that the lit airflow, which is shown when pressing the airflow switch, goes off once the selection has been made. The airflow seems to follow my setting, but why isn’t that icon continuously lit?
Discussion Starter · #7 ·
Thanks. I don’t mind that ADS is on. The airflow seems to follow my setting, but why isn’t that icon continuously lit? It’s lit only when making a selection. Once the selection has been made, the icon of the selected airflow goes off. Is that supposed to work that way?
1 - 9 of 9 Posts
