Not my car - happened in my city over the weekend. Managed to walk by it shortly after it happened.
Pained me as I'm still waiting for delivery on mine!
How!!!!!!View attachment 43513
I know ... thinking first swerved to avoid a cat ...and then they just thought 'sod it' lets test out the autonomous brakingHow!!!!!!
Wow... I wonder how the battery pack fared during that crash...View attachment 43513
Highly unlikely that's true. Even high performance cars don't have enough power to overcome the brakes.There's no way to car could have gone to such a high speed from "pressing on the gas instead of the breaks" and my dad is an extremely safe driver. Plus, they were literally about to park.
Even when you're literally parking the car at very low speed? There's a slight uphill going to the parking spot, so you have to press on the gas to go up. And then you let off as you come into the spot. You're using the gas pedal, not the breaks, to go up the hill. How can you end up using the wrong pedal to break? That makes 0 sense. It's been documented that this happened with Ioniq EVs, so it's not a stretch to say it could happen with the hybrid.Highly unlikely that's true. Even high performance cars don't have enough power to overcome the brakes.
If you unknowingly step on the wrong pedal thinking it's the brakes and the car accelerates instead, reflexes will will have you mashing HARD on the "brake" (actually gas) pedal to stop the acceleration - which of course only makes it worse. I had a similar experience long ago and even though I "knew" - exactly - what happened, subsequent analysis showed that was impossible. I had stepped on the wrong pedal.
I suspect the CAN-bus system on the car has detailed records of what happened (kind of like an aircraft flight recorder), and that data will show the gas pedal was pressed, not the brake.
This all harkens back to the then-infamous Audi 5000 unintended acceleration issue from long ago ('80s?). It was people pressing the wrong pedal. It happens when people go from one car to another with slight differences in pedal placement, or are situated in their car a bit differently from usual. It can happen even to highly skilled and careful drivers.
I'm open to being shown I'm wrong, but if the car suddenly accelerated, wouldn't your dad instantly stand on the brake? Or did the collision happen a short distance beyond where the car took off, within his reaction time to get on the brake?Even when you're literally parking the car at very low speed? There's a slight uphill going to the parking spot, so you have to press on the gas to go up. And then you let off as you come into the spot. You're using the gas pedal, not the breaks, to go up the hill. How can you end up using the wrong pedal to break? That makes 0 sense. It's been documented that this happened with Ioniq EVs, so it's not a stretch to say it could happen with the hybrid.
By the way, that very morning, my dad turned on the car, and it sounded like someone was pushing down on the gas pedal even though they were parked and he didn't a foot on either pedal. He turned the car off, turned it on, the sound was gone.
Something's definitely fishy.
