1 - 17 of 17 Posts
Hi all,
There's one thing I dislike about the Ioniq headrests and I think they're the same in other Hyundai's as well, because I know the i-10 has them: It forces your back and neck forward even when you try to lay back a bit and relax, so you're always sitting in some kind of halfmoon-shape, not good for my back aches! Does anyone know where to get other headrests that don't force your head foward this much, that would fit the Ioniq? So far google hasn't helped me much... Thanks! :)
The headrests on my front seats are adjustable fore and aft as well as up and down. I find them a perfect fit as I can adjust mine so that my head just touches the centre of the headrest when in normal driving position. This is as they should be to give maximum safety. A gap between head and headrest could result in whiplash injuries in the event of a sudden stop/accident.
Hi all,
Yep, I have a big head and turned mine around upon delivery. Fixed it!
They are adjustable and if I recall correctly you have to pull it forward in order to move it back.
Discussion Starter #6
I haven't tried this but what if you turned it around and installed it backwards when you wanted to rest?
This actually works quite well, thank you! :) We have a small neck pillow that can be attached to the seat and now we have the neck support from that pillow as well as the possibility to rest your head a bit without feeling like a banana 🍌
Does anyone know the part number for the UK adjustable headrests? The headrests are the only part of the Ioniq that I find uncomfortable. They don't at all fit me. Turning them around may work for a passenger when on a long drive, but not for the driver...
Mine are adjusted all the way and I still hate them. Hurts after about 10 minutes of driving. No other car does that. I will flip them around upon delivery but stay on the lookout for third party ones has it can't be safe to just flip them.
Well that sucks. My friends 2018 i30 is very comfortable, and I paid good attention to the headrests last time I was in it as I had recently discovered the neck pain caused by the Ioniq. Its weird Hyundai failed at making headrests, it seems so simple..considering others are (including Hyundai) are very comfortable.
Interesting that so many are apparently resting their head on the "headrests". Going to guess those doing so prefer a more reclined position than normal. The primary purpose of the headrest is whiplash reduction in case of accident. My head never touches the rest in any car I've owned or used, nor do I need one normally seated in a chair outside the car.
o
I agree yticolev and I do prefer a somewhat more reclined position than many folks. My DW who is 5'2 adjusts the driver's seat upright and as close as possible to the steering wheel in any car, so she can reach the pedals better. She often appears to be right up against the wheel.
The only car that I have ever driven that IMO had a truly ergonomic headrest that was in the exact right position to contact my head, but only if I so chose, was a 2019 Toyota Corolla Sport model that I rented for a return trip from Seattle to Vancouver two summers ago, just before I got my new Ioniq. It was a eureka moment for me, since I'd never been so comfortable in any seat as I was in that car. I was wishfully hoping for a similar experience in the my new Ioniq.
When my Ioniq arrived I realized that this was not the case and on further research soon discovered that some Ioniq models in other countries are fitted with an adjustable headrest and that I was not alone in my desire for a more comfortable driving position.
I do enjoy the Ioniq seating in general and I certainly feel no worse for wear after driving my car. If I had not driven that Corolla I would never have known that there could be a better fitting headrest. The rest of that Corolla ..... well, not so much. The seat and headrest were the best things about that car for me. ;)
Honestly, I don't rest my head on the headrest in the other cars I regularly drive (90s BMWs, 2015 Forester, 2018 Volt) but I am able to adjust the headrests to comfortable support my head if I want to. I can't help but rest my head on the headrest in the Ioniq because the headrest is so poorly designed and so far forward. I maintain a reasonably upright seating position too (literally as specified by the doc), I grew out of the gangster lean when I herniated a disc a decade ago.
Due to back problems I actually sit fairly right up, and that's why the headrest is so annoying: it's pushing my head forward by a lot.
If i recline the seat more, the problem is less, but still here.
Like others said, in other cars I do not touch the headrest, except when I want to for some head resting (hence the name) but in the Ioniq i HAVE to touch it, and it pushed my head which hurts my neck.
I like the extra space created by having the seat-back reclined somewhere between a gangster lean and hard against the wheel to allow me to get into the driver's seat more easily. I find it's more of a squeeze with the seat base/back positioned further forward. YRMV
Are forward-backward adjustable front headrests a UK-only option, or is it only on the top trim level? The headrests on my 2019 SEL only adjust up and down. What's worse is that they don't STAY where adjusted; as your head brushes against them, they move continuously upwards. The locking mechanism is apparently useless.
Annoying AF.
Annoying AF.
Nope. Mine has it and it's the medium trim level (2020 38k EV France)
1 - 17 of 17 Posts
