21 - 40 of 55 Posts
2019 Ioniq HEV Premium SE Intense Blue
ok so didnt work. :O
Here's what i did;
Formatted original SD card, copied everything from software download to this SD card, except cavenu_h folder then inserted into car.
Says nav not available, check SD card compatibility.
is there something i'm missing here??
Discussion Starter · #22 ·
can you post a screenshot of your system info screen so i can see version number and also post a screenshot of your sd card content
Discussion Starter · #24 ·
oh damn buddy,
the sd card content is wrong, i didnt know you downloaded the eu all software package. eheh, its okey my bad.
you need to download this package:
download, extract the content to a clean sd card. and insert into the car. nothing else :)
All downloaded, extracted, copied and inserted :)
Everything now works (y)
Thank you @SonicSpinner for your help
Ioniq Plug-in Hybrid Premium SE Polar White purchased new March 2018
Does the latest software for the 8" Ioniq screen make any worthwhile differences?
Hello. Can you please help?
I have updated the software but map no longer works. I have also tried the Kia map provided.
Screen shot of SD card content and system info screen. Any assistance greatly appreciated thank you
34461
34460
Discussion Starter · #34 ·
View attachment 34461 View attachment 34460 .
Hi, wow, i have never seen this model before, ever. what car do you have? and are you sure it has updated anything?? the date also looks last year. so i dont think you have updated.
please provide more info.
I have an i40 2016. Software and maps were updated last year.
This software update I believe did work as all the information has changed since. See older details below prior to update. Thank you.
34462
Not especially. I have found some nice relaxing sounds in there like forest, water and some others. The NAV, by the sounds of it has the most changes but I haven't had a chance to test yet.
The only thing I found I didn't like was when storing favourite radio stations it puts them in alphabetical order rather than your own order. There may be a way round this but I haven't found it yet.
If anyone else can highlight any exciting new things that come with the update, that would be great. I think just knowing you have the most up-to-date software etc. is quite nice :)
Thx for all helps. First i try installation and brick my headunit )) (loop hyundai screen), after i connect usb keyboard. Now all function work normally for my 2017 HEV. I can't found App Manager and Full Engineer Menu. If not install before App Manager, how can i make new install for 210111 firmware.
Discussion Starter · #38 ·
write to me in private and i will tell you how
Hyundai Ioniq PHEV 2019
[QUOTE = "SonicSpinner, post: 444741, címke: 20560"]
Hé srácok
Ismét kaptam egy kis élvezetet :)
ezúttal a hivatalos EU ALL Software április / frissítés áll rendelkezésre az LG és a MOBIS Standard 8 "fejegységéhez. Ezekkel egy kellemes csemege a Mobis fejegységhez, például:
Santa Fe TM, i30 PDe N, KONA OSEV / GSL, i20 2018.05.05 -> ;, Tucson TLe 18MY, i20 2018-
Ezeknek az egységeknek még nem volt alkalmuk frissíteni autójukat, mert eddig csak az LG egységekhez volt szoftverünk.
a térkép pedig csak a MOBIS, az EUR.14.41 legújabb verzióval
PS Azoknak, akik már alkalmasak a frissítéssel, április / májusra küldtem az LG-nek, nem kell újra frissíteniük.
linkek 1: Szoftver és térképek
[URL unfurl = "true"] https://www.swisstransfer.com/d/7dbc6312-54dd-43e7-81f4-336cfb52d4f2 [/ URL]
link2: Szoftver
[URL unfurl = "true"] EU All Software 2021 V1.2.zip [/ URL]
Link2: térkép 14.41
[URL unfurl = "true"] Mobis_Gen_5_0_MAP_EUR.14.41.42.453.zip [/ URL]
Ennek a szoftvercsomagnak ki kell terjednie az alábbiakban felsorolt összes modellre:
[ATTACH = teljes] 34372 [/ ATTACH]
[/ IDÉZET]
[QUOTE = "SonicSpinner, post: 444741, tag: 20560"]
Hé srácok
ezúttal a hivatalos EU ALL Software április / frissítés áll rendelkezésre az LG és a MOBIS Standard 8 "fejegységéhez. Ez kifejezetten egy kellemes csemege a Mobis fejegységhez, például:
Santa Fe TM, i30 PDe N, KONA OSEV / GSL, i20 2018.05.05 ->;, Tucson TLe 18MY, i20 2018-
PS Azoknak, akik már rendelkeznek a frissítéssel, áprilisra / májusra küldtem az LG-nek, nem kell újra frissíteniük.
link2: Szoftver
Link2: térkép 14.41
Ennek a szoftvercsomagnak ki kell terjednie az alább felsorolt összes modellre:
[/IDÉZET]
Lehetséges-e teljesen tiszta újratelepítés?
21 - 40 of 55 Posts
