Apart from engineering mode, today appeared a new hidden menu in the Infotainment system, you can see how it works in this video:
If you can't see the video, go to settings, screensaver, under the three options (Digital, analogic, no one) touch one time in each one until a PIN code appears, put the PIN that correspond with the ACTUAL time when you did and voilá! you can access to the complete Android system to check versions, ADB connect, all apps and so on!!!
Seems the Android version is 4.3 and there're 1.38GB space free in the system to install new apps and some other things >
Let's rolll!!!
Let's rolll!!!
