I purchased a new Grizzli Classic from Amazon to use on my '25 Ioniq 5 at home. When I hook up the car to the charger, the charger indicator light turns from blue to blinking green. After a bit I hear a relay on the car click, I get a message that charging session failed and to check the charger, The indicator light on the charger turns solid green, but no charging. I have had the car for a total of 4 days. I used the adapter that came with the acr at a fast charging station and it work without issue. Is there a setting on the car that I need to adjust/set? The power outlet is 240V with a 60 amp breaker.
Thanks in advance for any help!
Phatnine11
Phatnine11
