I have the same issue. How can I plan for a long drive if the ioniq 5 does not fully charge to 303 miles?
The car will charge fully if you so choose. Whether you get 303 miles range, or not, is entirely down to how you drive. Wind resistance losses go up with the square of your speed, and these losses dominate energy use once above 40-50 mph, so they really matter. Secret is to drive gently to begin with, and see whether your "reserve" is steady (ok), or decreasing (bad news). If decreasing too quickly, you're not going to make your destination, so either slow down, or plan to stop en-route.I have the same issue. How can I plan for a long drive if the ioniq 5 does not fully charge to 303 miles?
The car is fully charged when the dashboard shows the battery at 100%. How much range the car's software thinks you will get depends on the state of charge and its estimate of how much power you will use, based on your driving history. It does not mean that you can necessarily drive the estimated distance. You will not get as far if you drive with a lead foot, if its very cold, if your destination is significantly higher than your deparure point or if you're carrying a heavy load or towing a caravan. Conversely, if you see a low estimate because of one of the above reasons in your previous driving, you may actually be able to drive further than the estimate if you are driving more slowly/downhill/with less load etc.I have the same issue. How can I plan for a long drive if the ioniq 5 does not fully charge to 303 miles?
My RWD SEL 2023 is less than 2 months old. But driving at 70 mph means that it'll only go 265 miles with a full charge. For long trips (I have a 1,200-mile road trip coming up), you'll need to find a DC charger twice during the day and hope to be fully charged overnight to go 600+ miles. So get all the EV routing apps downloaded and start planning.I have the same issue. How can I plan for a long drive if the ioniq 5 does not fully charge to 303 miles?
