1 - 4 of 4 Posts
Hi All,
Does anyone know what the highlighted buttons do on the Ioniq (Hybrid) steering wheel?
Car Vehicle Automotive design Motor vehicle Speedometer
Couldn't find information about them in the manual.
Thanks!
On the hybrid they control the gear changes in Sport Mode.
If you weren't already in Sport Mode, then bumping a paddle to go up or down a gear will put you into Sport Mode temporarily. After 10 or so seconds without a manual gear change the car will revert back to normal mode.
On my 2020MY UK HEV, in Standard drive mode they control the level of regen. You increase it with the left paddle and reduce it with the right one. Pull the gear lever into Sport mode and they select the gears manually as KevinT says.
1 - 4 of 4 Posts
