1 - 5 of 5 Posts
Hello,
I just got my 2020 ioniq yesterday. I plugged it in at home with my flo charging station and everything seemed to work (it indicated that it was charging). The issue was that when I turned my car on this morning, I got a notification saying "charging interrupted" and the battery was only at 64%.
Can anyone tell me why and how I can fix this? This is an issue for me because I need more than a 64% charge to get to and from work everyday (I need a full charge). I am unfamiliar with how the car works, so is it something about charging settings or is it a malfunction?
HELP! This is not good for my range anxiety.
Thank you.
Welcome to this forum!
Are you sure there was no disruption of the electricity grid that night?
Do you have the Flo X5 or G5? If it's the X5 go to their web site and see if maybe there was a charging schedule set up for your station and whether the time zone was set correctly. Maybe it cut your car off early.
Reactions: Ionko
Moderator
Sounds like some sort of Time Of Use function may have been set up on the charger. Check it out. If your charger has a WiFi connection perhaps check it out on the mobile app at various times to see what it's doing.
Reactions: Ionko
Also you can check the charging schedule settings of your car.
1 - 5 of 5 Posts
