Intermittent Level 2 Charging
350 Views 7 Replies 4 Participants Last post by  Lonn
Last few times, level 2 charging stops intermittently. Went from 30 percent to 45 percent and stopped. Plugged charger back in and went from 45 percent and then stopped at 61 percent. Waited a day and went from 61 to 70 percent and then stopped.
Any ideas what might be going on?
1 - 8 of 8 Posts
It's likely this issue:
Reducing the charging speed in EV settings worked for me.
I think I am charging at 40 amps...so go to 32 amps and that might work? Guess it just slows the amount of time to charge the car, but not by that much?
Or, I just went into the car and went to EV settings. I see there are 3 levels of current: !) max, 2) reduced and3) a third lower level. Assume I can put the setting to the middle one, as it currently on the highest one? Thanks for your advice on this.
Yes, I'm on reduced. 8kw adds about 30 miles per hour, all I need for overnight charge.
Very common issue. I had it happen month or two ago. I can change the settings in my charger. Went from 40 to 32
Via the vehicle yes to the middle settings. The verbiage is vague. The latest software update has percentages
Alternate is to get the factory TSB when it senses the port temp is high it reduces the current
Yes it lengthens the charge time
Just got an over the air update last night coincidentally...will check to see if the percentages are there.
1 - 8 of 8 Posts
