Hi Guys! We finally got the latest software and map for Hyundai gen 5.0.
allthough it seems that there files for mobis units too in the package, but im not familar with them.
they are called daudio and daudioplus_m
GEN 5. (LG) (i10 IA, i30 PDe 06.2018->, IONIQ AE EV/PHEV/HEV)
Systemversion: XX.EUR.SOP.009.5.200731
MAP EV/PHEV: EUR.12.47.52.570.101.4(D.G2/E.G2)
Mirror 1:
Mirror 2: Smash (5 Gb ) Gen 5.x only
EDIT: NEW package upload 18.7 GB FULL BLOWN ALL SOFTWARE Hyundai 2020_2. We assume this big package is like previous years, where it fits all gen 1, 2, 3, 4, 5.x units,
Link: Smash
Edit: new updated and permanent link
software
Map:
The procedure is like the other times. This package is ristricted to LG headunits on Hyundai ioniqs. However a heaviere and more supported headunits package will be available maybe end of this week. For now this has been tested and updated on 2 different Hyundai ioniq 28,8. all went fine, the update took around 10 mins.
Normal installation for people with no needs to install 3rd party apps, and has no 3rd party apps installed on the unit:
Software:
1. Extract the zip file and copy the files to the root of your SD card ( the card must be formatted fat 32 )
2. Turn on the car and set it to parking. Insert it into the Sd card slot, and go to setting -< system info -> and press update.
Map:
2. insert into the Sd card slot, and it should load up the new maps. ( this is not tested yet, but i am sure it will work as intended )
Special installation for people who still wants to be able to install 3rd party apps in this new version,and has apps allready installed
This guide we assume to you allready know how to enter the engineering menu in fw 191209, if not, then you can check out here:
Short version: We have to factory reset the headunit and install appmanager, before upgrading the headunit.
1. Go to your engineering menu : And choose factory reset. This will delete all your 3rd party apps, and clean up the unit
2. Now go to the engineering menu again, and enable "prepare Auto test button" . Then you have to install APPMANAGER. with easy fire tools.
Appmanager: https://github.com/g4rb4g3/CtsTestStarter/releases/download/2.0.5/app-debug.apk
3. Once appmanager has done installing. you can now go ahead and update the headunit to the latest software
A). Extract the zip file and copy the files to the root of your SD card ( the card must be formatted fat 32 )
B). Turn on the car and set it to parking. Insert it into the Sd card slot, and go to setting -< system info -> and press update.
After the update has completed and headunit is on. press and hold the setting button. appamanger will now open.
from here you can open the full engineering menu on the list of all the apps. In the engineering menu you can enable ADB / or prepare autotest. and start installing apps again.
Mirror 1:
File on MEGA
mega.nz
Link: Smash
software
Hyundai_All_Soft_EUR_2020-2.zip
tinyurl.com
Map:
Maps EUR.12.47.52.570.101.4_LGE.zip
tinyurl.com
Software:
Map:
