US ICCU Recall (aka 12V battery failure issue). Please use the following thread, this pertains to all eGMP models. Please do not create duplicate threads on this topic. Thread
I just plug my phone in with the cable and get spotify through android auto, workds really and not slow. Saves space on the headunit.
Loving Newpipe btw, all i play is concert videos, and choose background while i'm driving
2018 fw has the classic screen Saver backdoor. YouTube hyubdai hacked headunit from the user kompkiller.
All you need is install 1 app only then upgrade to the latest fw. From there with this app you can open the full engineer menu and install apps through easy fire tools. I have a video on YouTube which shows how.
The app you need is called app manager
Thanks so much for all this info. I have successfully downgraded from 2020 to 2018, then to 2019 firmware, installed FileManager+ and upgraded to 2020 firmware again with the ability to sideload apps using EasyFireTools
I'm stuck on one painfully simple question - how do I get a qwerty keyboard up when needed?! (I'm trying to login in ABRPTransmitter and it only brings up a numeric keypad). Thanks in advance!
Hello mate and sorry to bother you, I've been trying to do the same on my hyundai and so far no luck.
can you please walk me through step by step on how to use the file to downgrade so I can do the same.
[QUOTE = "Парса, сообщение: 439833, участник: 24908"]
Привет, приятель, извини, что беспокою, я пытался сделать то же самое на своем Hyundai, и пока безуспешно.
Не могли бы вы рассказать мне пошагово, как использовать файл для перехода на более раннюю версию, чтобы я мог сделать то же самое.
заранее спасибо
[/ЦИТИРОВАТЬ]
Вам необходимо скачать архив CAVNEU_H, распаковать его на свой компьютер и скопировать полученную папку CAVNEU_H на sd-карту. Затем вставьте sd-карту в головное устройство, перейдите в пункт меню «Информация о системе» и нажмите кнопку «Обновить»
Ah, yes, started it up again and it worked fine! Doh, silly me for expecting the software to behave the same way every time!! If at first you don't succeed - reboot! Thanks for pointing out the obvious for me!
Next issue: ABRPTransmitter complains that it can't access location info - how do I get into Android settings for apps to turn on location for it please?
Download the Russian hacked firmware, then on an empty SD card, put the CAVEU_H folder (at the root) with its contents. Go to the car System menu, then Upgrade and click Upgrade, then put the SD card in and wait - it takes 5-10 minutes and goes through several reboots, but after that you should have the 2018 firmware.
[QUOTE = "SteveMac, сообщение: 439848, участник: 24728"]
Скачиваем русскую взломанную прошивку, затем на пустую SD карту кладем папку CAVEU_H (в корень) с ее содержимым. Зайдите в меню «Система» автомобиля, затем «Обновить» и нажмите «Обновить», затем вставьте SD-карту и подождите - это займет 5-10 минут и пройдет несколько перезагрузок, но после этого у вас должна быть прошивка 2018.
[/ ЦИТИРОВАТЬ]
Вы думаете, что человек глуп? Он не может прочитать то, что я написал, и вы делаете то же описание?
[/ ЦИТИРОВАТЬ]
Apologies, @olega, I did not take the time to translate your post from Russian to English, which I have now done My mistake. Thank you for your clear instructions and great work
[QUOTE = "SteveMac, сообщение: 439851, участник: 24728"]
Приносим извинения, [USER = 21074] @olega [/ USER], я не нашел времени, чтобы перевести ваш пост с русского на английский, что я сделал. Моя ошибка. Спасибо за четкие инструкции и отличную работу
[/ЦИТИРОВАТЬ]
You are welcome
P.S.
I wrote via google translator and was sure that there will be English text here.
If this is not the case, then I apologize ...
Hi, I want to install 3rd party apps on my ioniq 17 plate, HEV.
I just purchased a flash drive that I'm aware is required.
Can anyone please point me in the direction of a good walk through of the procedure.
Thanks in advance.
OK, so before downloading file in the browser I'm tapping on the address bar but there's no keyboard to enter address into the bar.
Any idea's. I'm not an expert!!
Thanks in advance.
Hmm I didn't do that either. Android setting is no longer available in the current fw. But I am almost sure I didn't do anything besides installing abrp transmitter and log in. Try uninstall reboot headunit and install agai
Holy moly. That's the oldest software version I have seen so far. The dealer didn't do jack.
You car needs some love for sure. What you need is to install appmanager only. Then update it to the latest firmware. Then start appmanager and then you can install apps though easy fire tools on an android phone.
[/ ЦИТИРОВАТЬ]
Hi Oleg, and thank you for your reply. And thank you for your nice work on the downgrade. No I'm not stupid. I did everything as instructed, extracted the file, formatted the SD card, copied the folder onto the root, inserted into the head unit, went to setting, update, pressed update and " please insert SD card containing the updat file" appears. I don't know what I do wrong. Thanks again for your work
201 - 220 of 270 Posts
