The Ioniq 5 comes with two battery options, 58 kWh or 72.6 kWh and two electric motor options (rear motor or dual motor).
With the 72.6 kWh battery and the RWD option Hyundai says you can get 470-480 km (292-298 miles) of range.
www.hyundainews.com
IONIQ 5 is available with a range of power electric (PE) configurations to fit the mobility needs of every customer, with no compromises on performance. Customers can select from two battery pack options, either 58 kWh or 72.6 kWh, and two electric motor layouts, either with a rear motor only or with both front and rear motors. All PE variations provide outstanding range and deliver a top speed of 185 km/h.
At the top of the electric motor lineup is an all-wheel drive (AWD) option paired with the 72.6-kWh battery, producing a combined power output of 225-kWh and 605 Nm of torque. This PE configuration can go from 0 km/h to 100 km/h in 5.2 seconds.
When equipped with two-wheel drive (2WD) and 72.6-kWh battery, IONIQ 5’s maximum driving range on a single charge will be around 470~480 km[4], according to the Worldwide Harmonized Light Vehicle Test Procedure (WLTP) standard.
Hyundai IONIQ 5 Redefines Electric Mobility Lifestyle - Hyundai Newsroom
