1 - 1 of 1 Posts
The Ioniq 5's E-GMP Platform can support 400V and 800V charging infrastructures.
With a 350-kW charger it can charge from 10-80% in 18 minutes and you can 100 km (62 miles) of range with a 5 minute charge.
The Ioniq 5 also has a unique Vehicle-to-Load function that allows you to charge things like electric bicycles, scooters or camping equipment.
Ultra-fast battery charging along with innovative Vehicle-to-Load (V2L) function
IONIQ 5’s E-GMP can support both 400-V and 800-V charging infrastructures. The platform offers 800-V charging capability as standard, along with 400-V charging, without the need for additional components or adapters. The multi-charging system is a world’s first patented technology that operates the motor and inverter to boost 400 V to 800 V for stable charging compatibility.
With a 350-kW charger, IONIQ 5 can charge from 10 percent to 80 percent in just 18 minutes. IONIQ 5 users only need to charge the vehicle for five minutes to get 100 km of range, according to WLTP.
IONIQ 5 also provides an innovative V2L function, which allows customers to freely use or charge any electric devices, such as electric bicycles, scooters or camping equipment, serving as a charger on wheels.
The V2L function can supply up to 3.6 kW of power. The V2L port is located under the second-row seats, and it can be activated when a vehicle is on. Another V2L port is located at the charging port on the vehicle exterior. Using a converter, customers can charge high-power electric equipment. The outside port provides power even when the vehicle is turned off.
1 - 1 of 1 Posts
