I'm trying to determine if I have a battery issue or if this is just normal for the conditions. We have a 2019 28K Ioniq which we bought new, so this is our 4th winter with it. Winters here get pretty cold (-15C to -25C or colder) and it seems to me that our battery performance is worse than it used to be. We know that range goes down as it gets colder, and that using cabin heating really sucks up the old juice, that's not the issue. The problem is that I don't get anywhere close to the predicted range. For example, after a full charge it might show 130km range (vs typically 200+ in the summer), but when I track the actual distance, I'm only getting 80-90km. I don't have this issue in the summer, predicted range is pretty close to actual.
I don't know if it's always been this way and I never noticed, or if something has changed. It was highlighted to me last winter when I had to run some errands with 32km range left. I only needed 12k for the trip, so I thought I was fine even if it took double the range. Well, it took a lot more than that. I had to shut off the cabin heat for the last half of the trip, and even then I just made it back with 4-5km left. Yes, it was very cold that day (-27C as I recall) and I was running the cabin heat, but the car knew all of that. If, under those conditions, I only had 10km why tell me I had 32km?
I've been keeping track of actual vs predicted for quite a while, and it's always way less in the winter. Last charge said 136 predicted, but I only got 69 actual, with a predicted 26 remaining, so something less than 95 actual (since I doubt I would get the full 26 predicted remaining).
So, is this the same experience everyone else has in cold weather? Is your actual range way less than predicted?
Thanks for any info!
Jean
Jean
