To get a better approximation of the range for low and high temperatures it is useful to take into account the losses in kW power for heating or AC. I made a computational model with some parameters for this and I want to ask whether from your experiences the values for certain temperatures are too high, too low or OK. I assume preconditioning took place and this indicates only the average power in kW to maintain the interior temperature during the driving. Note that it sometimes fluctuates between lower and higher, so then an average should be considered.
This is the graph for the current settings (with interior set point 20 °C).
P.S. I modeled the case that a heat pump is used (until -10 °C), as you can see in the curve of the line. For resistance-based heating you have to draw the straight line from -10 °C to the point 0 at 20 °C; see the dotted line in the second graph.
