Status
Not open for further replies.
Headlight LED bulb replacement part number.
571 views 2 replies 3 participants last post by  JerryP
My passenger-side headlight LED is not working,
and I'm looking for the replacement part number. The dealer is not helpful.
#2 ·
Ref your other thread (126) Check the headlight LED | Hyundai IONIQ Forum (advise keep one thread going as info from the first pertains to this)
- It was asked if in the original thread, is the headlight is working to which you replied "No, they are not, and tomorrow I’ll check the fuse. "
- Did not answer if you check fuse
- Did you check at the connector for power with a meter. I would do that before throwing a headlight at it.
- I do not know on this vehicle if the L/R headlight connectors are the same. On some vehicles they are. I would pull both headlights and test is indeed it is the assembly or a wiring/power problem
- What year is your vehicle? This is not covered under warranty?
#3 ·
Two threads asking the same question is asking for mass confusion. Thanks, @Neil F. Nice catch. I'll close this one and folks can get back to the longer thread you linked.
owns 2025 Hyundai Ioniq 5 Limited RWD
Save
Status
You have insufficient privileges to reply here.
