A bit of background.
The Ioniq 5 does not come with properly calibrated headlights from factory. Every dealer has to do that with the machine.
What is fairly specific to the Ioniq 5 is that the highbeam and lowbeam can be adjusted separately! This is not the case on many other cars.
If the dealer misses this, and does not adjust the highbeams properly, they will be pointing completely down, and it will look like in this video:
You will have a massive blob in the middle blinding you, and see nothing at all. This is because the highbeams are adjusted all the way down and the dealer did not set them correctly.
The car also will not pass an MOT like this (although not really very important for new cars).
After doing the proper adjustment there's a massive difference to the headlights. They actually work very well to see far instead of working against you.
Another thing I recommend (if the dealer will let you do that). Set the light corrector switch to 1 instead of 0, let them calibrate the low beam to spec (the corrector only affects the low beam, not the highbeam), and then raise the lowbeam back up to position 0. The end result is that you don't blind anyone but see a bit better - I tested this specifically with putting another vehicle (low car, not SUV) on the same street into the opposing lane and looking into the headlights, and it was not blinding at all. The spec is fairly conservative on these cars.
Here's a video showing correct adjustment against a wall:
