41 - 60 of 77 Posts
Discussion Starter · #42 ·
Thanks.
Can I run a session without driving just to get battery and cells data? How?
Does the app display DTC codes?
You don't need to drive but the OBD2 port should be active that means with the car ON or charging.
At this time the App does not show any DTC codes.
Ioniq electric Intuitive 38kWh - no bluelink - no heatpump
Hi all
Thank you for creating this app
Tried a few minute but failed on my Ioniq 38Kwh
Screenshot_20210119_154111_ev.watchdog.jpg IMG_20210119_154148.jpg Screenshot_20201130_134905_com.applagapp.elm327identifier.jpg
Any idea ? :)
Discussion Starter · #46 ·
It seems ok now, after having connected Torque Pro and Ev Notify.
When I came back on EV Watchdog, all data were read.
Very strange this Ioniq
Discussion Starter · #48 ·
OK, adapter seems generic which usually are slow and have compatibility issues (the App requires a certain feature of the ELM327 protocol to retrieve battery data).
Avoid to run other Apps that access the bluetooth interface while using the Watchdog, especially Torque which seems to lock the access.
You're certainly right. It works 1 time / 5. Thanks
Discussion Starter · #51 ·
v1.3 now available in two versions:
The existent free ad based version: EV Watchdog Free - Apps on Google Play
And a new premium paid version: EV Watchdog - Apps on Google Play
List of extended features of the premium version here: EV Watchdog Android monitoring App
Changes for v1.3
Free version:
  • Minimum supported API level raised to 16 (Android 4.1 Jelly Bean)
  • App's folder migration to Download folder (required for targeting API30)
  • Added file debugging
  • Added autostart prompt options
  • Fixed negative temperature values
  • Fixed freezing when starting live data from the cells chart screen
  • Several other bug fixes ands adjustments
Premium version, all the above plus:
  • Added notifications for cell voltage
  • Added average line for charts
  • Added Charge X Time and Temperature X Time charts
  • Fixed linear distance for near by stations
FAQ here: EV Watchdog Android monitoring App - FAQ
And be sure to join the dedicated fb group where I share all the developments: Facebook Groups
Hello, could someone confirm if these extension cables for OBD2 are any good? Can I use one of these and close the fuses/OBD cover on an Ioniq 28kWh? Thanks
Probably next step for me too
OBDlink ordered for a better compatibility :)
Now got EV Notify (Free) working on my 2017 BEV using Vgate iCAR 2 OBD2 ( mentioned as compatable on the website), which I purchased a couple of years ago. Took a bit of fiddling with the bluetooth settings in the phone to get it to connect, but got there in the end by deleting iCar2 and re-pairing. On occaasion since has not connected shraight away, but re-pairing sorted it. The app itself is great and very useful, especially the battery cell data. Still exploring all the information offered. Left the OBD2 plugged in with the car swithed off overnight and no indication of any 12V battery problems.
Thanks to @Watchdog for all the hard work in building this app.
Ioniq 38kWh
I'm using something like this for a longer time in Toyota Yaris Hybrid. Never had any problems (except of dongle-specific ones).
Discussion Starter · #57 ·
v1.4 now available
Changes for v1.4
  • fixed cost for kwh not parsing
  • fixed max temperature display (was showing min)
  • fixed pack size (39/64kWh) recognition for Kauai/Niro
  • upgraded db to v5
  • added edit cost kwh for trip card
  • added set cost kwh backwards for settings option
  • several other fixes and adjustments
  • added NearBy screen autoupdate option
  • added sync data option
Biggest change is for the premium version where the sync data option is now available.
In order to sync data to the web server do as follows (see attached screens):
1. activate the option in the settings menu,
2. agree data uploading,
3. go to the website sign up page (blue link in the dialog box) and register there providing your NetId code that was copied to the clipboard by the App.
4. verify your email.
33457
Then from the App make sure you are connected to a data network and hit the "Sync Now" option in the App's menu to force to send the data on normal usage this is actually not necessary as the App will try to sync several times by itself during operation).
Now log in to the website: https://evwatchdog.net, fill any missing info in your profile, read and agree with the terms and you're in. You should see all your data there plus other interesting graphical and tabular analysis.
Discussion Starter · #58 ·
v1.5 now available
  • Changed capacity calculation for battery card (now uses nominal voltage)
  • Upgraded db to v6
  • Added "Go!" button in charging station details for Maps*
  • Added charging mode
  • Added glide and regenerative braking distance
  • Several fixes and adjustment for charts screen*
  • Several other minor bug fixes and adjustments
* premium version only
Added charging mode which shows remaining time (to 100%), charged kWh and instant charging kW
33643
33644
New "Go!" button in the charging station details which will open Maps and set destination
33642
More info on the website: EV Watchdog net
FAQ: EV Watchdog net - Frequently Asked Questions
Download: EV Watchdog net - Download
FB group: Facebook Groups
Great app, I'm using a VIECAR OBD2 dongle (same as carista dongle) and it worked instantly. Very nice that it shows cell voltages even in the free version.
I tried with Vgate iCar Pro Bluetooth v4.0 on Ioniq 2020.
On my primary phone Sony Xperia XZ2 it mostly didn't work. App couldn't recognize the car model.
On my older Sony Xperia model the app worked more often, but not always. I returned the adapter and will buy OBDLink.
41 - 60 of 77 Posts
