EV technology in general and E-GMP in specific
Tags
e-gmp
1 reading
5.9K views 6 replies 6 participants last post by  Mathieu
I hope you enjoy it and learn a lot ;)
EV in General
As is well known, EVs use the electricity saved in the battery to cycle the motor and generate the power necessary for driving―this is the biggest difference to internal combustion vehicles, in which the engine exhausts fossil fuel to generate that power. As such, EVs have no need for the engine and transmission, the two of the most crucial components for internal combustion vehicles. Instead, EVs carry several components for electric power: the motor, the battery, the onboard charger, and the Electric Power Control Unit(EPCU). All are essential components to achieve the conversion of the battery’s electricity into the kinetic force that drives the EV forward.
1) Motor
The motor converts electric energy into kinetic energy that moves the wheels. The advantage of using the motor instead of an engine is numerous: first, the noise and the vibration we typically associate with cars are minimized. Many passengers riding EVs for the first time are surprised by just how quiet and comfortable the ride feels. Moreover, the EV powertrain is smaller than the engine, thus providing lots of additional space for efficient vehicle design―like expanded cabin space or storage.
The motor is also in part an electric generator―it converts the kinetic energy generated while in neutral gear(e.g. while the car is going downhill) into electric energy saved to the battery. The same energy-saving idea applies when the car is reducing its speed, culminating in the so-called “regenerative braking system.” Some of the Hyundai Motor Group’s EVs are equipped with a mechanism that can control the levels of regenerative braking via paddle shifters on the steering wheel, which not only improves the fuel economy but also adds an interesting and fun element to driving.
2) Reducer
The reducer is a kind of transmission in that it serves to effectively convey the motor’s power to the wheel. But it carries the special name―reducer―for a reason: the motor has a far higher RPM than that of an internal combustion engine, so whereas transmissions change the engine RPM to match the driving circumstance, the reducer must always reduce the RPM to an appropriate level. With the reduced RPM, the EV powertrain can take advantage of the resulting higher torque.
3) Battery
The battery stores electrical energy and is the equivalent of a fuel tank in an internal combustion engine. The maximum driving distance of an EV is often determined by the battery capacity―the higher the capacity, the higher the driving distance. In that light, increasing the capacity may seem an obvious choice, since a high driving distance reduces the annoying need for frequent stops at charging stations. But the choice actually isn’t so obvious, because the battery’s size and weight also have large implications on vehicle performance. The larger and heavier battery takes away from cabin/storage space and worsens the energy efficiency and fuel economy. The best way to optimize performance, then, is to maximize the battery’s energy density―that is, having a small, lightweight battery that stores as much electric energy as possible.
Thanks to the recent advancements in battery technology, the more recent EVs boast significant upgrades over older models in terms of battery density and driving distance. The Kia Soul Booster EV, for example, is equipped with a 64kWh lithium-ion battery that lasts for the max distance of 386 km(according to Korean certification standards). The battery life also saw significant improvements: assuming a normal pattern of usage, the Soul Booster EV’s battery can last through the entire life cycle of the vehicle. To explain in greater detail, understand first those lithium-ion batteries on EVs show battery life that varies with the charging pattern. If the charging pattern is such that the entire battery is exhausted and recharged to full, the battery can be used for 1,000 charges; if the battery is used to half(50%) and recharged, 5,000 charges; if one-fifth of the battery is used(20%) and recharged, 8,000 charges. Meaning, if the Soul Booster EV is driven for 77 kilometres a day(equivalent to 20% of the max driving distance) and recharged every night, the battery can last for 8,000 days(22 years)
Battery Management System(BMS)
The Battery Management System(BMS) manages the battery’s many cells so that they can operate as if they are a single entity. The EV’s battery consists of as little as tens to as many as thousands of mini-cells, and each cell needs to be in a similar condition to the others in order to optimize the battery’s durability and performance.
Most often, the BMS is built into the battery’s body, though sometimes it is incorporated into the Electric Power Control Unit(EPCU). The BMS mainly oversees the cell’s charge/discharge status, but when it sees a malfunctioning cell, it automatically adjusts the power status of the cell(on/off) through a relay mechanism(the conditional mechanism for opening/closing other circuits).
Battery Heating System
In lower temperatures, the battery sees a decrease in both charging capacity and speed. The battery heater exists to keep the battery within the ideal temperature range, preventing seasonal performance decreases and maintaining the max driving distance. The system functions while charging as well, ensuring the efficiency of the charge.
4) On-board Charger(OBC)
The On-board Charger(OBC) is used to convert Alternating Current(AC) from slow chargers or portable chargers used on home outlets into Direct Current(DC). This may make the OBC look similar to the traditional inverter, but they differ crucially in function; the OBC is for charging, and the inverter is for acceleration/deceleration. Incidentally, the OBC is not needed in fast-charging, since fast chargers already supply the electricity in direct current.
5) Electric Power Control Unit(EPCU)
The Electric Power Control Unit(EPCU) is an efficient integration of nearly all devices that control the flow of the electric power in the vehicle. It consists of the inverter, the Low voltage DC-DC Converter(LDC), and the Vehicle Control Unit(VCU).
1. Inverter
The inverter converts the battery’s DC into AC, which then is used to control the motor speed. The device is responsible for executing acceleration and deceleration, so it serves a crucial part in maximizing the EV’s drivability.
2. Low voltage DC-DC Converter
The LDC converts the high voltage electricity from the EV’s high-voltage battery into low-voltage(12V) and supplies it to the vehicle’s various electronic systems. All electronic systems in the EV use electricity in low voltage, so the high voltage in the battery must be converted first to be useful for these systems.
3. Vehicle Control Unit
As the control tower of all-electric power control systems in the vehicle, The VCU is arguably the most important component of the EPCU. It oversees nearly all the vehicle’s power control mechanisms, including the motor control, regenerative braking control, A/C load management, and power supply for the electronic systems.
E-GMP specific
When the driver turns on the car, the electricity in the high-voltage battery boots the vehicle and the system’s power on, in standby. When the gas pedal is pressed, the motor rotates and produces maximum torque. Then the EV transmission delivers the power to the wheels in accordance with the motor characteristics.
Principal Parts and Technologies
1. PE System
1-1. Motor
The equivalent of the engine in an ICEV, the motor produces the power by which the vehicle can run by converting the electrical energy in the battery into mechanical energy. The motor also serves as a generator during reduction, per the regenerative braking system*.
*regenerative braking system: converts the kinetic energy from elastic running (e.g. running downhill) into electrical energy, which is then stored in the battery. The system basically recoups or regenerates, some of the energy spent during braking.
1-2. EV Transmission
The equivalent of the transmission in an ICEV, the EV transmission adjusts the number of revolutions by the motor so that the electric vehicle can attain higher torque.
*EV Transmission Disconnector: the world’s first adaption on an EV vehicle, in which the motor and the drive axle can be connected or disconnected as needed. The mechanism enables free shifting between 2WD and 4WD.
1-3. Inverter
The inverter converts DC-power in the battery to the AC power used for torque control in the motor. The inverter power module comes with Silicon Carbide (SiC) semiconductors* that are more efficient than the existing semiconductors made with Silicon (Si).
*SiC semiconductors: Power semiconductors that use cutting-edge material Silicon Carbide (as opposed to Silicon) to convert/process/control electricity. They are sturdier, higher in thermal conductivity, and better conserves energy than the previous-gen Si semiconductors.
2. Vehicle Charging Management System (VCMS)
A central component of V2L* along with the ICCU, The Vehicle Charging Management System oversees all vehicle functions related to charging.
*V2L (Vehicle to Load): A technology that enables the electrical energy from the battery to be used by external devices. The maximum power output is set at 3.5kW due to certain parts specifications. If an In-cable Control Box (ICCB) is used, the system can also slow-charge another vehicle’s battery (V2V; Vehicle-to-Vehicle).
3. Integrated Charging Control Unit (ICCU)
The ICCU is an upgrade over the OBC, which only allowed one-directional charging from an external source to the battery. It now allows bi-directional charging, enabling the aforementioned V2L function.
4. Vehicle Control Unit (VCU)
The VCU is responsible for controlling most vehicle functions dependent on electricity, including the control of the motor, regenerative braking, climate control, vehicle electronics, and power supply.
5. High-voltage Battery
The battery stores and supplies the electrical energy needed to power the car. Inserting more battery cells into the battery increases the vehicle range, but it also makes the vehicle heavier and more expensive. Finding the point of compromise that best fits the vehicle model is key. Recent advances in battery technology have seen the gradual rise of battery energy density.
#2 ·
The Heat Pump
One source of inconvenience in driving an EV has long been the wintertime reduction of range: when the temperature falls, the resistance in the battery increases, leading to the reduction of range below normal levels. Moreover, unlike ICEVs, which can use the heat from the engine for cabin heating, EVs must use the electrical energy in the battery to do so, leading to a further loss of range.
Hyundai Motor Group sought to resolve these issues by developing a heat pump system with waste heat recycling, a step forward to the creation of a truly eco-friendly vehicle. The new heat pump system was installed in 2014 on the Soul EV for the first time, and it reduced the winter range loss by a remarkable 19% for the IONIQ EV. In addition, in part thanks to the heat pump system, the Kona EV came in first in the winter range test administered by the Norwegian Automobile Federation (NAF).
To be fair, similar heat pump systems are used by most other global manufacturers. But there is significant variation in winter range loss per vehicle brand and model. Hyundai Motor Group’s heat pump system uses not only the heat from the external air but also the waste heat from electronic vehicle components—e.g. the motor, OBC, EPCU/PE Module, battery, and slow charger—to heat the cabin. In essence, this capacity for “recycling” puts the group’s heat pump system ahead of its competitors.
#6 ·
I second the motion to make this a sticky. Will help a lot of people focus their questions.
I had a basic understanding of what is involved. Main part of working career,- motors, controls and refrigeration.
This cleared it nicely in my head. Thank you
Make that three votes, to be a part of the Pemament Information Section of this Forum. For this NEW to EVs, I found this both useful and NOT designed for someone with 'A Phd from Telsa U in EV science"!
