The apple wallet on iPhone stores a pass from the EA app on the phone which you can scan on the EA Charger, so you don't have to open the app to charge. But you can also initiate charging in the app, in both cases the first thing you do is plug into the car.Good info. I'm not familiar with Apple wallet. Does the charger recognize the car when plug is inserted, or do you use a phone app? Did you need to terminate the session at 30 min, to stay within the "free charge" sideboards? 150kW stations actually did slightly better than their labeled rate? Was your charge max set for 90%?
You do not need to terminate the session at 30 minutes, i did just to avoid additional fees and it wasn't a case that i needed more. Yeah a bit odd but I did see that the 150s report higher max speeds than you would think, not sure if that is actually delivered or not. Also I've come closest to the 20-80 in 18 minute benchmark on a 150, so not sure what's up with that.
I have modified the max charge based on the scenario, with a road trip i max it out but for normal driving max it at 80%. This gives me the most bang for the 30 minute limit.
