Not necessarily. Once it arrives at the port, you'll be able to see the window sticker that contains information about the port it arrived at.Does every Ioniq go to PA port? I'm purchasing mine off of Autonation Corpus Christi and it's at AA status 9/4 est delivery.
Call your dealer and ask which portDoes every Ioniq go to PA port? I'm purchasing mine off of Autonation Corpus Christi and it's at AA status 9/4 est delivery.
I don’t remember exact name of vessel but I’ve seen the ship stopped at Philly port then heading to GA (Brunswick port).Does every Ioniq go to PA port? I'm purchasing mine off of Autonation Corpus Christi and it's at AA status 9/4 est delivery.
The port of entry should be stated in the upper left corner of your window sticker. The lower right corner under the bar code has a hint about the name of the ship it will arrive on. Be aware that these ships all kind of have the same name, and that the hint will only help point you in the right direction. For example, there are nearly 50 cargo/vehicle carrier ships with the word MORNING in their name. The easiest way I've found to narrow it down is to use this webpage, but it only works if your car has already been delivered to the port.Call your dealer and ask which port
Other cars from that dealer list the Port of Entry as "NC". But I can't quite figure out what port that is, exactly.Does every Ioniq go to PA port? I'm purchasing mine off of Autonation Corpus Christi and it's at AA status 9/4 est delivery.
Maybe Wilmington North Carolina?Other cars from that dealer list the Port of Entry as "NC". But I can't quite figure out what port that is, exactly.
Yeah I would guess Wilmington or Morehead CityMaybe Wilmington North Carolina?
What I understand is….Window sticker is created when the car arrives at port.So my car had an original delivery estimate date of 7/21 and keeps getting pushed back, now 8/10. Looks like there are many others on the same boat. It showed up on the spreadsheet on 7/8 and has been in AA status since then.
Does anyone know what ship it is on? Window Sticker says GLOVI, but there are so many Glovis ships. Port is Philly.
Are you absolutely sure about that? I have the window sticker from the dealer, but the VIN on hiepcs site says "AA" still.What I understand is….Window sticker is created when the car arrives at port.
X2. My understanding is it's live when the vin is assigned which is why we were using them to figure out what ship was bringing our cars to what port.Are you absolutely sure about that? I have the window sticker from the dealer, but the VIN on hiepcs site says "AA" still.
Try from the dealer website. Window sticker is available when the car arrives to ports from dealer’s website. Probably dealers can access window stickers anytime.Are you absolutely sure about that? I have the window sticker from the dealer, but the VIN on hiepcs site says "AA" still.
Window sticker also clearly says "GLOVI" on the barcode.
An example:Are you absolutely sure about that? I have the window sticker from the dealer, but the VIN on hiepcs site says "AA" still.
I didn't think the window sticker was on the website, because the dealer just text it to me. But I just checked and the sticker is now on the website too! So maybe the car reached the port and the status will change soon on the spreadsheet.An example:
My car arrived at the Port of Philadelphia on 21 June, was presumably unloaded on 22 June, and the sticker showed up on the 23rd. It's status changed to PA on 25 June.
Then probably it came early with other ships. Both Asian majestic (arrive today) and Glovis crown (arrive tomorrow) still are at the sea so status should be “AA”.I didn't think the window sticker was on the website, because the dealer just text it to me. But I just checked and the sticker is now on the website too! So maybe the car reached the port and the status will change soon on the spreadsheet.
EDIT: Just noticed Glovis Crown is expected in Philadelphia tomorrow, 7/24. Maybe that is the one.
EDIT 2: Just checked hiepcs this morning and status changed to PA! Nice to see some movement finally.
Possibly your car might transit with railroad then delivery truck to your dealer…….So, our SEL the port of entry is NC and the ship is K.ASI on the window sticker. It looks like the vessel is "K.ASIA BEAUTY" looks like it's going back to Korea? only made a stop in California. Car is supposed to end up in Corpus Christi, TX.
199 A 2042VK.ASIIf you guys can post the digits above the barcode in the bottom right hand part of your window sticker, I may be able to help you determine which ship your car was on.
If the sticker is posted and you can pull it up, that means it is at a port. It's already there, awaiting inspection and pickup by either rail or truck transport.
For instance - mine 196 A 2063QASIAN
Don't know exactly what the 196 or A mean, but the 206 is the 206th day of the year - July 25th, 2022. This corresponds to when my car arrived in Philly and it was at this point that I could pull up my sticker. The 3 indicates the model year's last digit (for instance, a 2022 would show a 2 here). The Q is also unknown to me. It arrived on the Asian Majesty. My car did not switch from AA to PA until yesterday.
TN means transport ready
IR means in transit (via rail)
IT means in transit (via truck)
DS means dealer stock
These statuses are HIGHLY inconsistent right now and really mean nothing. As do your ETAs. Could show up weeks early, or weeks late.
Of course, the port is in the top left of the sticker. As far as I know, Hyundai only uses 4 ports to deliver cars built in Ulsan Korea. Portland, OR, Hueneme, CA, Philadelphia, PA and Brunswick, GA. Wilmington is not a port that they use.
