Coolant type for 2023 Ioniq 6
102 views 3 replies 4 participants last post by  Surfside6
Hi,
The coolant levels on my 2023 Ioniq 6 SEL are low. I was wondering what type of coolant I should use to top it off?
Thank You
#4 ·
From the repair manual it appears that Hyundai has a proprietary (I can't make out a brand name on the instrument) device for its leak testing. As you might imagine, it's not a simple process...draining, disconnections, pressurizing with helium, the leak tester...
I am trying to remember if some ICCU failures were internal-leaks related..?..
In any case you should contact your service center, and monitor your coolant level closely until you determine it is or is not still leaking, and proceed accordingly.
[Cooling Mode (Battery Cooling Mode)] (there are also similar "AC mode" and "battery and AC mode" depictions)
