I have not seen any information regarding turning them off in any of the tests on the Ioniq 5 that I have seen!
Could you not stick some masking tape or similar over them?
I suggested masking tape as it is relatively easy to remove when requires!A bit of black insulating tape will do the job.
If you cut it nicely then it'll look just fine.
SB
I've not got one - you can tell us about it after you've made oneDo you remove it before the charge port is closed?
A colleague with a 3D printer is making me a neater one (as shown in an earlier post), but with a couple of hours going spare, I went full out Blue-Peter mode this afternoon & made a Charging cover out of some foam packing - on my 4th attempt!You could even make your own 3D printed cover (although I think I'd rather take the "Blue-Peter" route & cover a bit of old lino with Sticky-back-Plastic)
I've printed a couple of these - one in "remove before flight" red and a black one to be a bit less obvious.You could even make your own 3D printed cover (although I think I'd rather take the "Blue-Peter" route & cover a bit of old lino with Sticky-back-Plastic)
And the charge port lid/door can still close with that on?I've printed a couple of these - one in "remove before flight" red and a black one to be a bit less obvious.
Yeah, I expect you'll need to have max a couple of mm thickness. Someone made the 3D version linked above and it also was too thick for the lid to close. Don't know the thickness of that one.Just tried to close the flap with the 7mm thick high density foam version - Its a Fail![]()
The 3D print model is 2mm thick, but it's easy to scale. The ones I printed I made 1.6mm and you could probably go down to 1mm if you wanted and it would still be robust enough. I don't have the car yet to test if it will close.Yeah, I expect you'll need to have max a couple of mm thickness. Someone made the 3D version linked above and it also was too thick for the lid to close. Don't know the thickness of that one.
Great! Are these thin enough for the lid to close normally? Also, could you check with him if he will ship abroad?My nephew made one of these for me with his 3D printer, and has made a few more to sell on ebay. If anyone is looking for one then search for ioniq 5 charge light cover if you're interested.
