When it's touted as a major feature, you'd expect you could actually use it. So far, I've played with the granny charger twice, and one L2 charger that one time I went to the office between covid outbreaks, and otherwise charge 2x/week at EA fast chargers. To 80-85%. If that significantly degrades the battery sounds like a defect to me.
I'm guessing you're new to EVs. It's easy to make assumptions you shouldn't. It's not obvious to you that you shouldn't use maximum capacity charging for your EV all the time, but it IS obvious to you that you shouldn't use maximum horsepower output from your ICEV all the time. (Because duh, that'll wear it out quicker, and not because the engine is defective.)
When EVs become as familiar as ICEVs, misunderstandings like yours will go away, and people will just 'know' what they should and shouldn't do. It will become embedded in our social/cultural/technological common sense. So while we're still learning the ropes we should be more open-minded about what should and should not 'sound like a defect'.
{EDIT}
The other side of this is that, as a long-time EVer, I cannot comprehend why anyone with an EV would want to go somewhere else to charge their car, when one of the killer advantages of an EV is never having to go to a gas station again - and only needing fast charging in those rare instances when you're on a road trip.
Even if your fast charging is free, there's just not enough savings to make that worthwhile.
When you charge at home, your charging time is effectively only a few seconds. However long it takes to plug in when you come home and unplug when you leave. The actual charging happens in the background while you're doing other things. It's not like you have to stand there and wait for it or even stroll somewhere to kill time. I guess if you're coming from a gasser that's a hard paradigm shift to adjust to, but it sure is nice when you get there!
Of course that does not apply if you're one of the many who cannot charge at home. Apartment dwelling, street parking only and other similar barriers are the last great challenge to completing the transition to EVs. It's hard because it's so variable on such a local scale, but we'll get there.
