1 - 15 of 15 Posts
Does anyone out there know how to change the digital display from mph to kmh?
Yes.......as far as I am aware you cannot.:crying:
Though I'm not sure what you mean by "digital" display. Certainly the speedo is fixed as MPH or KPH according to country and the small digital figures under the centre of the dial will read the opposite to the main display and these cannot be changed. There is also the option of a larger digital readout on the information section to the right of the speedo. I'm not sue if that can be changed.
In my other vehicles I read the digital number for how fast I am going in kmph. I never look at the dial ( not sure what it is called). In the Ioniq the dial is in kmh and the digital display is in mph. I want them both to be in kmph. Unless I drive to the USA I don't need to know the mph.
I hope there is a way to change it. Haven't found one yet.
It can't be changed in UK, there is a Km/h digital display in middle of speedometer, a digital mph selectable on right of speedometer display.
As an alternative you can use android auto with Waze to display speed on multimedia display in either Km/h or mph
Another alternative is a android mobile phone app "GPS Speedometer and odometer" by cool niks
I think that as your main "speedo" display is in Kph the ancillary digital display (to the right of the main speedo display)that you can select, by using the left hand of the 2 right hand toggles on the right of the steering wheel and then the up/down toggle switch underneath, to display Kph in large digital numbers.
On Canadian vehicles, the only units capable of being changed are the Fuel Economy units, and those can only be switched between L/100 km and km/L. No other option for those units and no options for any other units on the car, unfortunately.
That can NOT be changed. if the dial is KPH the digital will be in MPH, and if the dial is MPH the digital will be KPH. I'm in USA and I want them to be both MPH, unfortunately it can't be.
There is an option to disable the KPH display under the spedo so you don't have to look at it. I prefer the accuracy of the KPH. 1.6 vs 1.
Of course. Metric has always been known for it's precision. It's the reason why medicine has used metric for so long.
My mum's dad, who sadly passed away when I was about a year old so I never knew him, had been a pharmacist in New England in the 1930s and 40s and served the US in WWII in that capacity and he always praised the metric system for its precision.
Does anyone know how to change Celsius to Fahrenheit and back?
It should be somewhere in the car settings. On the screen to the right that you control with the steering wheel, go to user settings, go to other, then go to temperature unit and select there. Switching to Fahrenheit will change all the outside indicator and Auto A/C to Fahrenheit.
Check 3-97 is you user manual for more information.
I've actually had to do this recently, a couple of times, as for some reason on the Canadian models, the temperature display units revert to Fahrenheit each time the battery is disconnected. (You'd think for a country that uses only Celsius, they could make that the factory default for that country...but that's the subject of another discussion entirely.)
Anyhow, on the right side of your steering wheel, press the top left button until the right side of your dash is in User Settings. Use the toggle switch just below it to scroll down to "Other Features" and press OK (will either be the toggle switch itself or the button below depending on if you have Smart Cruise Control or not). You should see Temperature Unit in this list, and you can change it there.
see https://www.ioniqforum.com/forum/3-new-member-introductions/30510-quick-tour-round-dashboard-menus.html for a quick tour round the dashboard menus and how you can change things
1 - 15 of 15 Posts
About this Discussion
10 Participants
bluecar1
Hyundai IONIQ Forum
Full Forum Listing
