1 - 5 of 5 Posts
Hi,
I have a problem with my Inioq 5 while charging with CCS. The car stops charging after 0-5 minutes. With the message "Charging cannot be started. Unexpected vehicle status"
First I tough it was the charging station because after a couple of tries the charger got out of service
The day after, i tried other one, with same problem... and a third one aswell....
Right now I have no problems charing at a AC charger. What can the problem be?
Ioniq 5 RWD Ultimate 73 kWh
Hi,
Did you ever get this fixed? I've ran into a similar problem since last weekend. The car will now only charges via AC. DC won't even start with "Unable to communicate with car" error. I've tried 5 different networks and at some chargers that worked before too.
Hi
I took the car to the dealer and they replaced all the wires inside the car.
I got it back from the mechanic yesterday and will test if it worked this weekend.
So sadly you need to take it to the dealer
Hi
Yeah, it's back at the dealer. They've tried updating the charging firmware and that didn't fix it.
Hi
Was it fixed for you? My car is waiting for replacement parts for the charging unit.
1 - 5 of 5 Posts
