1 - 10 of 10 Posts
Does anyone of you experience echo heared by your contact using the Carkit? Mine does quite annoyingly. In bluetooth as well as Apple carplay. I own an Iphone 6. Any solutions?
I experienced the echo only while using Apple CarPlay. It turned out the radio had to be replaced. Updating was not possible without replacement of the unit. All problems are solved now. Thanx!
My radio unit is also replaced, but the echo is still there! I used Apple CarPlay. What is your version in the unit? Firmware en software?
Very annoying that Hyundai give no information about the last update names.
Funnily enough, my dealer found the same issue when carrying out the 10k service and has placed a warranty claim to replace the radio - so clearly the firmware issue isn't the solution to that particular problem. But if the radio replacement isn't going to solve the problem why replace it? I'm quite happy with it's performance in all other areas.
Here you go, hope this is helpful, they sometimes change the unit but don't update the software, this solves the echo issue
1 - 10 of 10 Posts
